Linde E25 01 336 - help please, some troubles
Hi people,
I'm working on a machine who burns the instruction panel and with a new one all lights go on and gives me a turnback signal of 80v to the 80/24v converter. The linde console don't turns on when I connect with the traction module. Someone can help or have a manual of this machine to I can see the wiring diagram?
Thanks,
  • Posted 14 Feb 2014 05:12
  • By filipe_f
  • joined 13 Jan'14 - 26 messages
  • ----, Portugal
Showing items 1 - 20 of 34 results.
This is a great device! I found some more information on this website: www.directindustry.com/industrial-manufacturer/contactor-70014.html
  • Posted 13 Jun 2014 18:00
  • By lebois_m
  • joined 13 Jun'14 - 1 message
  • Marseille, France
Good to hear, must have been an expensive fix. Fixing forklifts on a sunday morning?
  • Posted 11 Mar 2014 05:46
  • By frits_f
  • joined 19 Dec'09 - 315 messages
  • utrechte, Netherlands
Hi one more time mates. All problems solved. I start from the beggining like friend AMartins said and the last problem was the directions switches, in 1X13 i need to close circuit between pin 6, 13 and 20. only have voltage in 20 and 13 so one of the direction switches was faulty but I need to change both because when i'm testing the truck turning all wheels to the side of the old sensor the error comes. Summarizing this truck have a lot of problems since wire problems in a lot of places, all the 3 temperatures sensors from motors faulty and the one from the hydraulic motor was sending 80v to other components, new display, traction and hydraulic controller, power module of traction and a lot of hours spent... but now is working well. Thanks to all who helped, I'm really grateful.
  • Posted 9 Mar 2014 22:02
  • By filipe_f
  • ----, Portugal
hello my friend Filipe, I read your big problem, but I tell you, starts from the beginning, disconnect every cables and every circuits, start now in correct connection, cable by cable with a ommeter and see a any bad connection, if a possible error of conection, because I had a problem at wiring at articulation of cabin cut some wires, or any short at wires, see the diode circuit from motors. Well my friend good luck in your job.
  • Posted 9 Mar 2014 11:54
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
Sorry for the late reply, didn't get a notification email.
The curve switches are on the steering axle. They shut of the engine of the inner wheel when making a curve. This error occurs when the switches say the truck is in both left and right curve at the same time. (from memory, both switches open). So check the wiring and the switches.
  • Posted 9 Mar 2014 08:20
  • By frits_f
Right, I've been study some manuals who people send to me and I realise that is a regen contactor. The wiring diagrams I have are not readable, can't see the numbers and it's difficult to understand.
Thanks for the info, i'm looking for what is provoking this error and translating to portuguese what means curve swith signals.
  • Posted 5 Mar 2014 06:47
  • By filipe_f
  • ----, Portugal
OK right. That changes things. You don't have a maincontactor: the big contactor is regen contactor.
errorcode 39 : unacceptable combination of curve switch signals.
Good luck.
  • Posted 4 Mar 2014 23:13
  • By frits_f
It's a E25-01 with hydraulic levers and classic direction contactors.
  • Posted 4 Mar 2014 18:39
  • By filipe_f
  • ----, Portugal
I'm a bit confused. Is it a E25-01 with hydraulic levers and classic direction contactors, or a E25-02 with joy-sticks and only one main contactor?
  • Posted 4 Mar 2014 07:34
  • By frits_f
It was one of the first things I did! Now I just have error 39 and can't find a reason for it!
  • Posted 4 Mar 2014 07:12
  • By filipe_f
  • ----, Portugal
Just a thought, Is a motor cable shorted to the chassis? Use your ohm meter and check the resistance between the chassis B+, B-, motor cables etc. Should be multiple kohms at least. (with no battery attached). Could be the cause of a most of your problems.
  • Posted 4 Mar 2014 06:36
  • By frits_f
You are talking about relays 9K1 and 9K2?
  • Posted 3 Mar 2014 02:45
  • By filipe_f
  • ----, Portugal
look for 2 small relay in de back
  • Posted 1 Mar 2014 16:33
  • By michel_v
  • noord holland, Netherlands
Problems solved. Have hydlraulics but no traction, traction controller have error 39 and main contactor is open.
  • Posted 28 Feb 2014 20:51
  • By filipe_f
  • ----, Portugal
Cables repaired, not have negative on exit of converter, now it's allright. "With this accident" I dont have hydraulics again and can't communicate with traction controller.
  • Posted 28 Feb 2014 02:37
  • By filipe_f
  • ----, Portugal
Thanks, I'm looking for a mistake in the cables to the main contactor. By the way I found some trodden cables and accidentaly put 24v direct on the exit of 80/24v converter but in the cables of the machine not into converter, the converter have the plug off so it didn't suffer anything but when I plug the battery it make short circuit, I turned all off and repaired the cables and connected it right this time. Now I have 100V in the IN of the converter 80/24 when it supposed only have 80V. I don't understand how it's possible or what I burned to it happens...
  • Posted 27 Feb 2014 07:02
  • By filipe_f
  • ----, Portugal
39 Both intermediate-circuit voltages less than 35 V
46 Fault signal of main contactor tripped
  • Posted 27 Feb 2014 03:49
  • By michel_v
New traction controller connected, Now I have errors 39 and 46, I don't know why 39 happen because the battery have 83V. 46 talks about cabin switch and it's OK too... I'm a little lost right now...
  • Posted 27 Feb 2014 00:43
  • By filipe_f
  • ----, Portugal
New hydraulic controller arrived and mounted, Finally have hydraulic but no traction... I can't communicate with traction controller with Linde console, I think it burn too... waiting a new one...
  • Posted 26 Feb 2014 07:07
  • By filipe_f
  • ----, Portugal
I think the truck without display should drive very slowly
  • Posted 25 Feb 2014 02:36
  • By michel_v
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Toyota 8HBE30
Flesherton, Ontario, Canada
UN Forklift FB25N1QZ1
Orlando area, United States
Tacoma, WA, United States
Highland, IL, United States
