E228 error code
Hello everyone.
I have a case of forklift BT RRB1/15. This forklift is moving well, but the hydraulic pump is not working. When the pump should start working on the CID displays an error E228. I have no service manual and error codes. Maybe someone could help me find out what this code means?
Thank you in advance for any help!
  • Posted 26 Jan 2014 21:52
  • By Arkadiusz_M
  • joined 26 Jan'14 - 6 messages
  • Iława, Poland
Service and Repair
I replaced the transistors MOSFET w60n10 in driver and it works! Forklift is already a month in work and is all good. THANK YOU ALL for your help and information.
  • Posted 2 Apr 2014 02:16
  • By Arkadiusz_M
  • Iława, Poland
wtc pvt ltd. can repair this one.
  • Posted 27 Feb 2014 20:16
  • By shashank_v
  • joined 27 Feb'14 - 22 messages
  • Haryana, India
shashank_2436@yahoo.in
SV
TVH can repair these grey I Motion controllers now.
  • Posted 28 Jan 2014 20:45
  • By Forkingabout
  • england, United Kingdom
A2 lift regulator has a grey cover. When an error 228 is appear, green LED starts flashing. I checked a short circuit on one phase of the A2 regulator. Damaged power Mosfet transistors w60n10. I'll try to replace them and I will let you know what's next.
  • Posted 28 Jan 2014 19:10
  • By Arkadiusz_M
  • Iława, Poland
A2 card is the lift frequency convertor.
There should be a green led on top of it, what colour boxes have you got?
White or the later grey / black ones?
Also check the multi plug electrical connection to A2.
Swop it with the A1 card & see if the fault then moves to the traction side of the truck.
Its extremely rare for a frequency convertor to go down on a Reflex, I've only seen one fail in 8 years plus another one that the apprentice blew up changing the maxi fuse - he dropped his spanner across all 5 terminal studs & the capacitors discharged with an almighty flash & BANG.
  • Posted 28 Jan 2014 08:58
  • By Forkingabout
- Hydraulics did not even budge.
- A2 card? Do You mean a lift regulator? If so, I do not see any LEDs on its casing.
  • Posted 28 Jan 2014 01:47
  • Modified 28 Jan 2014 03:13 by poster
  • By Arkadiusz_M
  • Iława, Poland
Service and Repair
This truck hasn't got a CID as it's an older Reflex.
E228 = Lift regulator AC current too high
1. Motor cables incorrectly connected.
2. Defective pump motor
3. Lift regulator [A2] defective.
Are the hydraulic not working at all OR are they extremely slow?
What's the green led showing on the A2 card?
Check the 3 motor cables are correctly connected, you can swop the 2 frequency convertors around if you suspect it's faulty as a test.
  • Posted 26 Jan 2014 22:03
  • Modified 26 Jan 2014 22:26 by poster
  • By Forkingabout
Todd J Doxsee Todd J Doxsee
Sales operations, Heli
Chief financial officer, Cyngn
Executive vice president and chief commercial officer, East Penn Manufacturing
Terberg YT220
Enforcer FD50T-MMA
Dayton OH/Cincinnati OH, United States
Prospect CT, United States
Davenport, IA, United States
Philadelphia, United States
Brothers Adolf ("Adi") and Rudolf ("Rudi") Dassler split their shoe company after WWII due to a bitter feud, and established the rival companies of Adidas and Puma. Their personal animosity and business rivalry divided their German hometown Herzogenaurach. The town became known as "the town of bent necks" due to the intense loyalty to each brand.
