Clark TM15S
Hi Everyone,
I have a TM15S (1980 24volt)that take off like a snail, and when the double contractor kicks in it hauls butt(jumps)for a second, but then drops out like it over loads. The happen's in both forward and reverse. Up on blocks everything works as it should. It seems like a thermal trip? I'm stumped on where to start! Any help sou be appreciated.
I bought a service manual from holt out of California for $148. It only has wear troubleshooting in the hydraulic section.
  • Posted 25 Jan 2014 05:45
  • By pineddy
  • joined 8 Jan'14 - 12 messages
  • Nevada, United States
Fix it like it's your own equipment!
look on the motors tags and see if they show the voltage rating of the motor.
if they say 36/48v then you have your answer
wrong battery voltage or wrong control panel in it maybe?
i can see having a transformer onboard to downgrade the voltage to 24v but theres no way to squeeze 36v out of a 24v battery.
  • Posted 3 Feb 2014 15:14
This has a cableform controller. It is on a hinge and flips up. I pulled the SCR unit last night. I was looking at the label and in voltage it has "36-80". Could this be the wrong SCR because I have a 24 volt unit?
Could it be dropping out because it thinks it's low voltage?
Do they make drop in's for this, OR does someone have a troubleshooting book or web page?
  • Posted 3 Feb 2014 07:50
  • By pineddy
well if you have to ask maybe you should get someone more familiar with electric trucks to take a look at it.
But... on that note...
this forum strips url's from entries so you will have to remove the spaces i added from the url and copy and paste it in your browser address bar at the top to go to the site page.
a EV100 panel looks like this:
h t t p ://w w w.fsip.biz/Documents/EV100.pdf
the reactor usually has a decal on it saying EV100
a EV1 panel looks like this:
h t t p ://w w w.fsip.biz/Documents/EV1.pdf
the control card usually has a decal on it saying EV1
a 210 panel looks like this:
h t t p ://w w w.fsip.biz/Documents/M210.pdf
no identifying decals, you just have to know what this one looks like
if none of these are what you have then go to that site and look through the panels they show and find the one you have and let us know so we can help you.
good luck
  • Posted 28 Jan 2014 00:33
Snoowp233
how do Ib tells wjtch one Y have?
  • Posted 27 Jan 2014 14:43
  • Modified 27 Jan 2014 14:45 by poster
  • By pineddy
sounds like your getting a PMT
Being it is a 1980 model it is unlikely it has EV100 in it, most likely EV1 or maybe GE210 panel?
  • Posted 26 Jan 2014 00:54
Tacoma, WA, United States
Highland, IL, United States
Orlando area, United States
Dallas, TX or Lexington, KY, United States
Terberg YT220
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
