Jungheinrich Code 25 ?
Now this EFG316K FN370993 has stopped running. You turn the key on and the dash flashes as normal, then code 25 INF008 shows and nothing works. The battery gauge shows 0%. The battery is charged and at 52.5 volts. Troubleshooting says check canbus connection, check proportional valve - modulator connection. I don't know where the proportional valve is. I did find a broken wire in the harness to the seat that had been pinched in the hinge and shorted to the frame that I think was the previous problem with it shutting down while driving. Any ideas where to check? You think a dealer can connect a laptop and diagnose this fairly quickly?
  • Posted 3 Jan 2014 05:52
Follow up: I found that the positive cable on the truck that goes from the battery to the emergency kill switch had worn through the insulation and was touching the frame. Then one of the wires to the seat switch was pinched in the battery cover hinge and shorted to the frame also. That blew the control card (interface).
  • Posted 7 Jan 2014 06:23
Hello, I've had this problem and found burned fuzivel 1F8
edmar
Brasil
  • Posted 3 Jan 2014 06:20
  • By edmar_p
  • joined 18 Jan'13 - 49 messages
  • Guarulhos SP, Brazil
Toyota launches three new stackers Columbus, IN, United States
VETTER Forks, Inc.
Hangcha CPYD25XW71F-C
Flesherton, Ontario, Canada
Unicarriers FHGE35T5S
Highland, IL, United States
Dallas, TX or Lexington, KY, United States
Orlando area, United States
Tacoma, WA, United States
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
