timing belt change
i,m just about to change timing belts on my trucks but can,t work out which part number as our parts cd will only display german.job looks straight forward enough. anything i need to watch for guys ??
  • Posted 2 Oct 2007 06:24
  • By kevin_k
Kevin, make sure you lock down the cam shaft
  • Posted 22 May 2015 12:11
  • By edward_m
  • joined 11 May'15 - 111 messages
Hi Kevin what are you after the part number or what the job entails,is it a 39 truck?If so Diesel or Gas?
On the 39 range with the VW engine it is pretty straight forward,remove side cover and all timing belt covers,remove bottom pulley and you can see the timing marks.You don't need any special tools.I also mark up my own reference marks as well.The belt adjuster has a mark on it for correct tension.If its a diesel you may need to fine tune the pump timing but you can have to do this with the lap top.
Hope this is what you wanted to know ta.
  • Posted 4 Oct 2007 02:17
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
Hitachi HX64B2
Terberg YT222
VETTER Forks, Inc.
Hitachi HX64B2
Terberg YT222
