L289/L292
Hello, I have a Linde H40D serial number is H2X394TO3995. When I try to go up or tilt I get code L289/L292. Can some one tell me what this code is. Thank You.
  • Posted 13 Dec 2013 02:53
  • By cgarner1979
  • joined 13 Dec'13 - 24 messages
  • Alabama, United States
Talked to a Linde tech, safety valve is also referred to as relief valve. It is located on the side of the main control valve that points straight down. I had a bad connection from oil leaking into plug from a hydraulic hose busting a few days prior to the codes. Thanks for telling me what the codes meant.
  • Posted 17 Dec 2013 05:30
  • By cgarner1979
Thanks for the information. Can anyone tell me what the safety valve is, or what safety valve current is low is referring to.
  • Posted 14 Dec 2013 02:11
  • By cgarner1979
Thank you! Could you tell me what that is referring to, I have no manual or information at all on the linde we have.
  • Posted 13 Dec 2013 05:34
  • By cgarner1979
L289 = Safety valve current low although activated.
L292 = Safety valve always OFF.
  • Posted 13 Dec 2013 03:53
  • By Forkingabout
  • england, United Kingdom
Terberg YT223
Ice 24INCH-AUTO-SCRUBBER
USD6,396
