Trans fluid?
What type of fluid does the cgc25 take?
  • Posted 4 Dec 2013 02:57
  • By Jtech81
  • joined 4 Dec'13 - 2 messages
  • Michigan, United States
Thanks for your response. This has seep rate dipstick for the hydraulic fluid. So I guess it's the ta30. I just got it back from a job and had a complaint of it takes 20 seconds before it will move when it's cold. It appears someone has put red transmission fluid in it. I didn't think that was right. I do have some traveller universal tractor trans/hydraulic fluid. Will that do the trick? It is approved for wet brake. I have a few Yale glc moles that require it.
  • Posted 5 Dec 2013 01:16
  • By Jtech81
That will depend on if I has the TA-30 Trans axle or if it's hydrostatic drives....the hydrostatic uses oil from the hydraulic system....the TA-30 uses Clark Part # 2776236 which I believe is 30 weight tractor oil
  • Posted 4 Dec 2013 03:42
  • By kevin_t
Tusk 350CGH20
Taylor TX330S
USD159,500
