Mutiple Trouble Codes
Been trying to find some place that has trouble codes listed and been unsuccessful.
These are the codes we get on occasion. Seems we can shut it down for a minute then it is fine for awhile.
T225
T235
T222
T232
Any help would be appreciated!
  • Posted 28 Nov 2013 08:48
  • By SwampDonkey
  • joined 28 Nov'13 - 1 message
  • Missouri, United States
Joystick is worn out and try to have tilt angle sensor calibrated or try to calibrate joy sticks.may need to replace gears in the tilt angle sensor.
  • Posted 15 May 2015 11:07
  • By edward_m
  • joined 11 May'15 - 111 messages
Is this 2-traction pedals truck or 1-pedal with the direction switch?
If it's 1-pedal, check the direction switch or the cables around (specially the connection between the switch and the N1 mower module.)
These are the 225,235 errors.
232 it's the traction potentiometer issue.
It may be defected, the cables around may be broken, or the small gears linked with the pot may be faulty too.
222 should have L (lift) in front - not T (traction).
It means, that the main working hydraulics functions joystick (the left one) is defected.
  • Posted 28 Nov 2013 23:51
  • Modified 2 Dec 2013 22:14 by poster
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
