Code A08
Hello,
My raymond got a problem : when the selftest ends, the lift fall in the A08 test mode (I think it's the test because I can read the value of the heat sensor from the main drive).
My question is : how can I go out from this A08 mode and use again my lift?
I want to add : when I'm in this mode, the battery indicator shows an empty battery even if the battery is good. Is it normal?
Thank you for your help.
  • Posted 20 Nov 2013 07:57
  • By yoann_h
  • joined 21 Jun'13 - 13 messages
  • Quebec, Canada
you might find the the winning lotto Quebec numbers sooner than "superword"
It could be anything!
Peut tre c'est....J1 et les 3 derniers numro d'ordre ou GNJ1 avec les 3...
  • Posted 23 Nov 2013 14:42
  • Modified 23 Nov 2013 14:44 by poster
  • By EasiTek
Yes normally, I will check. Do you think I will find the new superword in it?
It could be great
  • Posted 21 Nov 2013 23:13
  • By yoann_h
  • Quebec, Canada
Do you have the operators manual that is supposed to stay with the truck?
  • Posted 21 Nov 2013 09:11
  • By forktech418
  • joined 31 May'12 - 19 messages
Hi, thank you for your answer.
Now I'm facing a new problem : the superword is not the default one... To change that, the only option is to call a raymond tech?
However the password is the default one so I can enter with it.
I already got the A08 message and I succeed to clear it in the password mode, I went on default setting and after I was ok for maybe few day, after that the A08 code pops up again...
  • Posted 20 Nov 2013 23:10
  • By yoann_h
  • Quebec, Canada
Yes you are in the Analog test mode 08. It was highlighted when someone scrolled through the tests. So it stays on while in use. You must access superword and get into the Analog tests. At A08, you would see a star beside it, indicating it's active. Hit the horn button to uncheck it. There is also a prompt to "clear active maint"
Are you able to access superword?
  • Posted 20 Nov 2013 11:04
  • By EasiTek
