Difference between Komatsu FB15A_12 ( usal) and Hybrid
Hi all, Please tell me how difference between 2 class of this model,
I bought 1 Komatsu Fb15 A-12 Hybrid but no have battery, then i change the other battery but can not switch on the power, Tell me how to connect direct to this forklift can operate ( i'm hearing from others Technical say : they connect at socket to operate, but they don't say more..)
hELP ME nOW.
  • Posted 10 Nov 2013 18:30
  • By pham_s
  • joined 15 Dec'12 - 81 messages
  • 12, Viet Nam
phamquocsy9@gmail.com
Thanks edward_t so much, i understand your ideas, I send you file attached, can you tell me more detail about this
Please check your email.
  • Posted 11 Nov 2013 02:40
  • By pham_s
  • 12, Viet Nam
my guess is this truck has an "SBX" type of battery connector, and your older battery has the SB connector.
The SBX connector in the truck is designed to have a connection that is a closed circuit between the small middle connectors that disconnects -before- the larger power cables loose connection. this is to prevent damaging power spikes when the larger power cables are disconnected or connected. At least that is how I see most of them used these days.
putting a jumper wire in the wire circuit for the middle connection may help get the truck running or for testing, but there is a VERY good reason for having that middle connection, and disabling it will eventually cause damage to the [high dollar] controller, that would otherwise never happen.
if this is the case, you will need to get a jumper set of connections to allow the SB connector on the battery connect to another SB connector, and have a properly wired SBX connector to connect to the truck, that will be the jumper that provides the completed circuit through the small SBX connection.
  • Posted 11 Nov 2013 00:07
Toyota 8FD35U
Flesherton, Ontario, Canada
Toyota 8FD45
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Orlando area, United States
Dallas, TX or Lexington, KY, United States
Tacoma, WA, United States
Highland, IL, United States
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Toyota launches three new stackers Columbus, IN, United States
