Battery Light Stays On
GM 3.0L
Our battery light on this truck stays on constantly.
Charging output is normal. (voltage regulator has been replaced)
Battery is brand new.
Never runs low on charge.
Any input on what can be the issue?
  • Posted 9 Nov 2013 02:15
  • By rodney_m
  • joined 6 Aug'10 - 20 messages
Voltage readings perfect throughout the range of idle, mid, and WOT.
Cause of concern: selling the truck.
Found resistor in LED light board burnt out - causing light to stay on - replaced and is now good as new - dealer stocks these items as they sell often.
P/N: 30595 for those who may need it in the future
  • Posted 15 Nov 2013 07:45
  • By rodney_m
describe further "normal" as far as voltages, at rest, starting (with load) running at idle right after start, and then wide open throttle. then confirm no voltage drop by reading voltage though the meter with the cable disconnected from the battery/ key and lights off, reading between the disconnected cable end and disconnected battery post.
OR ignore it, if everything runs good, it may be that someone before changed it to a 1 wire alt. what made you decide to be concerned? what made you put a new battery in?
  • Posted 9 Nov 2013 09:45
  • Modified 9 Nov 2013 09:46 by poster
Possibly is a broken wire from the alternator connector up to the light,or the light it's self.....I don't have a schematic for it just going by how other trucks are wired that I've looked at
  • Posted 9 Nov 2013 09:20
  • By kevin_t
Hoist Liftruck F180-36BOX-CAR
Toyota 02-2TD20
