Clark TMG25 S/N TMG248-1905-9570KF code A66
I am working on a Clark TMG25. The truck shows code A-66, has full travel but no hydraulic functions. I have read other posts that refer to thies trucks being hard on motors and controlers so if anyone has any advice as to what to look out for, that would be great.
THANKS
  • Posted 2 Nov 2013 02:49
  • By RAFARMER
  • joined 17 Jan'12 - 153 messages
rafarmerjr@gmail.com
Thanks for the post Kevin, I will check out all that you listed and will post the results as soon as I can get back on that truck.
RIchard
  • Posted 5 Nov 2013 08:37
  • By RAFARMER
This is from the TMG manual for a code-66
Read the LAST Paraghragh....... It is a TMG my mistake...the slave is throwing the code....read on last paragraph
Description:
FET field protection has shut down.
Causes:
Bad fuse, should be checked for excessive volt drop. Do not check fuse w/ohm meter.
Line contactor tips welded open. Repair line
Verify that there are no motor field shorts. Motor fields should measure 0.6 to 0.7 ohms.
Verify that there are no cable shorts between: B+ and F1 B+ and F2 A2 and F2
A1 and F2 F1 and F2
All of the above to frame
An A66 will be generated in the Slave control anytime the Master control opens the Line contactor (PMT). Both controls interpret the sudden loss of B+ as a 66 code.
  • Posted 2 Nov 2013 05:27
  • By kevin_t
You Sure this is a TMG truck...I don't think their codes will show an A before the code...is it a TMX AC Drive truck? If so following is the description for a code 66:
When battery level reaches 20% or less or (10% on the dash display), the current level for the drive motors is reduced to 50% of the programmed level and the lift function is locked out.
  • Posted 2 Nov 2013 04:43
  • By kevin_t
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Tacoma, WA, United States
Orlando area, United States
Dallas, TX or Lexington, KY, United States
Highland, IL, United States
