Error code E16-2
no acceleraiion, can any body help
Hello folk's.
I have a problem with TOYOTA 8FGL20 on the display is error
E 01-2, on gasoline works well but on LPGI not really.
I included the calibrator on the fork but nothing because I do
not know which are the parameters for sensors,so please if anyone has
any information or service manual please send to tabak_08 at hotmail dot com
Thanks in advance.
Thanks electrotech ,going to site this week and hope to fix.
hi terry tfm the idle switch is located around the throttle area in conjuction with a stepper motor when the motor drops to idle it engages the switch in conjuction with the stepper see if the switch is depressed at idle as if it is not set right it will cause this code also check wiring connectors pull wiring make sure its not broken in the connector see how you go
Hi electroteck,thanks for your reply ,could you tell where the idle switch is located as I have not worked on a series 8 before and have no info or diagrams
best regards to down under
TerryTFM
hi terryfm your fault code relates to idle switch short circuit see if it is working properly
