HYSTER E2.00XMS Error code - 16
model E2.00XMS , 1999 year, 48v.SERIAL No D114A02726W
Error code - 16, there is no movement
need a manual, any help
  • Posted 10 Oct 2013 06:46
  • By alexandr_k
  • joined 6 Dec'11 - 197 messages
  • Ukraine, Ukraine
code 41 is internal temp exceeded in controller.allow to cool it should be ok.check for causes of overloading or the internal temp sensor has failed
  • Posted 17 Nov 2019 03:39
  • By stackerhacker
  • joined 2 Mar'18 - 87 messages
  • glasgow, United Kingdom
Hi,I have problem with the same machine. Error code 41. Help me!
  • Posted 16 Nov 2019 16:46
  • By Andrey_Mihaylov
  • joined 16 Nov'19 - 4 messages
  • Bulgaria
Alexandr, check mail box
Regards
  • Posted 11 Oct 2013 05:59
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
nacsand at hotmail dot com
code 16 is usually battery over voltage. have you used a handset to set the voltage of the controllers to the actual battery voltage rather than a default setting for 36&48 volts? what happens in a dead battery 48 volt truck if the setting is the default, the controller may think it is a too hot 36 volt battery rather than a too dead 48 volt battery. that would be my assumption. setting it to the actual battery/truck voltage (function 17 I think, off the top of my head) should fix part of the problem and the other part will be fixed when the battery is good.
  • Posted 10 Oct 2013 20:02
Mike Barker Mike Barker
President and CEO Swisslog Americas, Swisslog
Vice president, Newgentech Material Handling India
Sales representative, Alabama and Panama City, Thompson Lift Truck
Chief marketing officer, Bobcat Company
Elwell-Parker ESI500-36
JLG 600AJ
JLG 600AJ 2012
Flesherton, Ontario, Canada
