Load Indicator Attachment with SHUT OFF option
anyone knows if their is any load indicator attachment that will shut off automatically if it reached the maximum load???
thank you very much,
  • Posted 25 Sep 2013 12:09
  • By air_flight
  • joined 22 Jul'05 - 14 messages
  • National Capital Region, Philippines
Hallo
Please go to ravas-dot-com and fill in an enquiry in our web-form attn Jacob - then I will get it in my regular email system and can answer you by email
on YouTube ( search for: ravaseuropetube ) you can find many applications of mobile weighing systems
rgds Jacob
  • Posted 22 Oct 2013 15:59
  • By jacob
  • joined 11 Jun'04 - 11 messages
  • Zaltbommel, Netherlands
weighing without compromise
Hi Jacob,
Can you help me further with this. Is this an attachment that i need to attach? And where can I buy this attachment?
Thank you.
  • Posted 22 Oct 2013 14:43
  • By air_flight
You could use the relais also to activate a flashing lamp or beacon which you can only reset using a master key of the site manager ??
  • Posted 11 Oct 2013 17:21
  • By jacob
Thanks for all your reply. Right now, our clien is using load indicator with the sound off buzzer when exceeded. And right now this system never works because of their hard headed forklift operators. Plus the fact that their yard have an uneven flooring which most of the time adds up to the dilemma. Mamagement is now considering to have additional device to protect their forklift units. Buzzers definitely is not working. Your additional suggestions would be greatly appreciated.
Thank you
  • Posted 11 Oct 2013 10:30
  • By air_flight
There's no other way.... than to be #1!!!
Dear Karait thanks for your answer - you describe our very accuracte RCS Plus hydraulic weighing device which needs to have the forks lowering action.
Our RCS Overload system works in a different way - it will sense the pressure at all times and gives a buzzer warning when the load exeeds the set limit. We would not recomend to switch out functions of the FLT for the obvious reasons.
We have installed hundreds of those systems all over world and all works good.
  • Posted 11 Oct 2013 03:45
  • By jacob
I would'nt recomend such solution.
For normal, hydraulic pressure measuring devices like RAVAS or NEXO
the weighing process of the load goes like this:
You get the load, raise it to some prescribed level and push the button. The load goes down (40-70 centimeters - depending on the calibration) and the weighing process is done - you get the result on the display.
Just imagine, that the you exceed the maximum load 5 kG and system will totally shut off your truck with the load raised, somewhere in the middle of the aisle. Total disaster.
I'ld rather trust your truck. When you exceed the load ~ 20% while lifting, the relief valve should simply open and disable the lift.
Or, as PPPA suggested, calibrate your weighing device maximum load on higher level and install some beeper.
  • Posted 11 Oct 2013 01:14
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
You'd be better with a audible warning instead of shut off.
You'd need an over-ride on the shut-off so you can get the load off the forks again.
  • Posted 10 Oct 2013 19:37
  • By PPPA
  • joined 8 Sep'05 - 25 messages
  • United Kingdom
RAVAS Europe BV makes these instruments !
It is called the RCS and works from the hydraulic pressure.
It also works as a load indication device.
For extreme accurate weighing we recommend the iForks !
see us at Inter Airpot in Munich 8..11 october
  • Posted 26 Sep 2013 14:34
  • By jacob
Taylor TT300
USD98,500
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Taylor TT300
USD98,500
USD1
