Adding headlights to Yale reach truck - How to do the wiring ?
What would be the easiest voltage connection point to run the wiring and the on/off switch for headlights ? And seeing as the truck is 24 volts, would the headlights typically be 24 volts or would I use 12 volt bulbs and a voltage reducer ?
And what would be a good aftermarket source of forklift headlights.. ideally with the metal guarding like in below example) ?
For example of what I mean see below sistership-
ebay.com/itm/YALE-NR040AE-STAND-UP-REACH-TRUCK-NARROW-AISLE-FORKTRUCK-FORK-FORKLIFT-HILO-/141039369095?pt=Forklifts_Other_Lifts&hash=item20d699fb87
(add you know what [dub-u dub-u dub-u.] to the beginning of that URL to make it work. This forum software is set to block full URLs)
  • Posted 23 Aug 2013 21:55
  • Modified 23 Aug 2013 22:10 by poster
  • By Milacron
  • joined 25 Nov'06 - 80 messages
I can't comment on the wiring but your best bet is to go with LED lights. These come in multi voltage any where from 12 to 80 volt. The may seem expensive up front but by the time you figure the cost of changing bulbs LED is cheaper in the long run. These are available from any forklift dealer and several aftermarket sources.
  • Posted 23 Aug 2013 22:16
  • By Partsguy5
edition #1243 - 14 August 2025
In this week’s Forkliftaction News , we look at more financial reports with one major producer recording a “significant” decline in Q2 bookings to report an operating loss of USD8.5 million, while another had a strong quarter “despite increased trade tensions and a challenging geopolitical landscape”... Continue reading
Dwight Klappich Dwight Klappich
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Executive director, NT WorkSafe
Chief executive, Logistics UK
Combilift Ltd
The black box flight recorder was invented by Australian scientist David Warren in the mid-1950s. While initially met with indifference in Australia, his invention gained international recognition, particularly in the UK, and is now a mandatory piece of safety equipment on all commercial aircraft.
