Cat - GC25K - Brake pedal - Back up alarm
Hello all, I have a few of these units pop up with this issue:
Pressing the bake pedal and you will hear the faint noise of the back up alarm on??? I suspect faulty wiring, relay or Diode. wondering if any techs have had this issue. Let me know Thanks
prenticelift at gmail dot com
  • Posted 8 Aug 2013 04:03
  • By Prentice
Swoop is correct. Another option is to replace the factory lights with a LED version, eliminates the ground loose issue. JW Speaker offers a direct replacement
  • Posted 10 Aug 2013 00:08
  • By Partsguy5
Thanks Gentleman, I will give a full report soon
  • Posted 9 Aug 2013 22:02
  • By Prentice
kevin is the most likely scenario
i've ran into this many times on the cat's with the light bar assy's and the multifunction lights.
if you check the ground terminal in the light assy you will find it is loose. They are only riveted onto the ground plate and they do get loose over time causing the bad ground, since the ground in this circuit effects the brake, park and reverse lights it may cause erratic behaviour in any of those circuits.
You can try to remove the rivet and put a screw in it if you want but it generally is wise to just replace the light assy as the labor to repair it cost more than the light and swapping it out.
Also check the wiring in the OHG, there is a plug just inside the OHG that may be corroded. It may be located just at the base of the OHG leg where the harness enters the OHG or at the top where it comes out (all depends on the configuration and model year).
  • Posted 9 Aug 2013 21:14
this indicates a poor ground on the area where the alarm is mounted (?on the overhead guard?) and that the current has found an easier path to ground through the alarm rather than straight through the frame. a diode and a small capacitor could act as a filter, as would fixing the ground path.
  • Posted 9 Aug 2013 19:51
Great thanks kevin_t.
I will look at the tri-lights on the OHG
  • Posted 8 Aug 2013 22:00
  • By Prentice
Now that I've racked my memory and thought about it a little I remember.....truck I had did have rear combination lights and one had an issue with a short in it and the brake light was dim on that side and was back feeding(shorted) and causing the BU Alarm to sound...very lightly not loud tho,like your saying yours are doing
  • Posted 8 Aug 2013 07:55
  • By kevin_t
Do the trucks that are doing this have rear combination lights(brake,Backup, turn)? I did have this problem once with one of these it was several years ago and if I remember right it was either in the wiring going up thru or by the OHG Rear pillar post or it was in the light assembly itself....if it has brake lights check to see if one is dimmer than the other....I believe it was in the light assembly and was shorted somehow to the Backup light bulb....even if it dosent have the lights in the back the wiring will be there along with the plugs and connections....look for rubbing and chafing in the harness..the back up alarm is feed by the same wire that operates the backup lights
  • Posted 8 Aug 2013 07:38
  • By kevin_t
edition #1242 - 7 August 2025
In this week’s Forkliftaction News , we take a closer look at the main theme coming out of the recent CeMAT Australia event in Sydney: automation; why some are holding back and why not everyone will automate... Continue reading
October 15-16, 2025 - Las Vegas, United States
November 13-14, 2025 - Berlin, Germany
David Wells David Wells
Chief executive, Logistics UK
National business development manager, Roadpod
Senior vice president, PEAC Solutions
Board director, UKMHA
In 1923, French tennis player René Lacoste was promised a crocodile leather suitcase by his captain if he won his next match. He lost the match but won the nickname "the crocodile" which he had sown onto his tennis attire. Ten years later he launched the first polo shirt and Lacoste, the first brand to feature a logo on its clothing.
