JUNGHEINRICH EFG316 error 0802
good morning
i have the following problem with the efg316
when turn the key on i have an empty screen with error 0802
do you know what is the problem?
thank you
  • Posted 26 Jul 2013 20:00
  • By ioannis_p
  • joined 26 Jul'13 - 6 messages
  • dodecanissos, Greece
Showing items 1 - 20 of 34 results.
Hello team
On ERE 120 we have problem error code
E 0802. 13
Please any help
  • Posted 29 Jun 2025 00:36
  • By Shpend_Musliu
  • joined 29 Jun'25 - 1 message
  • Kuwait
CAN node shows no
response.
Check power supply of the CAN-Bus component
not found.
- Check parameter setting for the optional
component, e.g. Option ISM, Option Can Code,...;
- Via JUDIT try to access the faulty component;
- Check the physical properties of the CAN Bus;
- Measure the CAN-Bus signal;
- Check CAN-Bus signals for frame leakage;
- Check equipotential bonding;
- Check terminal resistances (60 ± 10%);
- Bypass components connected to the CAN-Bus
in turn;
- Replace controller
  • Posted 20 Oct 2023 07:16
  • By Cyril_Hadzor
  • joined 18 Sep'23 - 3 messages
  • Ghana
Cyril
HELO
You should always check the version and yearbook of the tool
  • Posted 30 Aug 2021 00:22
  • By rotemj
  • joined 3 Aug'19 - 10 messages
  • israel, Israel
rotem.J
I had the same error 0802.
I solved the problem, changing the electronic board, where are the lever to up and low the nails.
  • Posted 22 Oct 2020 01:31
  • By Duende1978
  • joined 25 Oct'18 - 3 messages
  • Mexico
Hi friend
All you must do is please the forklift. They have feelings you know. Clearly you have not treated yours right. We have equal rights for minorities and women, why not forklifts?
  • Posted 30 Sep 2020 03:08
  • By Gavin_Haley
  • joined 30 Sep'20 - 1 message
Gavvy_Patty
Hi friend. Have you already solved this problem? If you have, can you please explain how you did it? If not yet, I am giving you a related breakdown list that might help you. Regards
  • Posted 26 Sep 2020 00:01
  • By nparra84
  • joined 25 Sep'20 - 1 message
  • Central, Paraguay
nparra
Hello
Have same 0802 on my EFG 2009. Is there any fix? Can anybody send info to sc57 at g m a i l. c o m
Thanks Patrik
  • Posted 4 Dec 2019 06:13
  • By Patrik
  • joined 4 Dec'19 - 1 message
  • Finland
It is the small sw60 contact as suggested above. I had this problem today. Tips were not making and after replacing contact. Problem solved.
  • Posted 29 Mar 2019 09:34
  • By elektrodrive
enquiries@elektrodrive.co.uk
loss of supply voltage.
Do you have a circuit diagram?
  • Posted 25 Mar 2019 16:46
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
Please help me
Jungheinrich -EFG 110 -FN350228 - Year 2006 - Error code 22 + 38 + 94
I have tried to remove all the controller such as : ACS-Hydraulic Power Module & Drive Power module (in the back: P/No.50287976-Unit-impulse control / INMOTION), the Canion Controller (in the front; Part Number 50287978-Unit-impulse control / CANION) as well as the Operating Display to install all of them in to the good truck => as the results, this truck is still able to work as normal. => This means that all 4 control units are in good function.
I have replaced the complete wiring harness (Part number 52024948 - all wiring of the truck).
But it is not help me at all. It still alarm 3 error codes mentioned above.
  • Posted 24 Mar 2019 04:33
  • By Nunanemo
  • joined 24 Mar'19 - 24 messages
  • Viet Nam
Cheers
Nuna - Ho Chi Minh City
Email: dairongservice1973@gmail.com
Website: xenangdairong.com
Geroj.
I have the same problema Err 0802. Could you help me please to share me error codes manual????
Best Regards.
  • Posted 9 Mar 2019 10:47
  • By Duende1978
  • Mexico
Hi friend
Hello, can you please help me with error 0802, the forklift is an efg 318 k? Tanks in advance! Email boggo_87_bogdan*yahoo.com
  • Posted 3 Dec 2018 18:14
  • By albu_b
  • joined 17 Jan'18 - 5 messages
  • Romania, Romania
Can you please help me with this error 0802, what does it mean? I am getting it on my forklift efg 316k
Thank you very much
  • Posted 25 Oct 2018 08:22
  • By Sapimih
  • joined 25 Oct'18 - 1 message
  • Serbia
Order no. 51169229 is not found in ETM / V 214/216.
51169229 is an interface card.
The serial number of the machine helps.
  • Posted 23 Oct 2018 05:40
  • By geroj
  • Krivan, Slovakia
Do you have a serial number for this truck ?
  • Posted 23 Oct 2018 04:18
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
Hello Geroj,
An overseas client of mine has shortly ordered a spare part (Motor controller/ Interface Board) for his ETV216 2013 Model. Part number was 51169229. Now that he has finally received it and was trying to installing, he keeps receiving the above mentioned error (0802).
So he tried to get smart and removed same part from a similar Reach Truck and the machine worked without an issue. The part I have supplied him is brand new and doesn't have any issues.
Following that, he contacted Jungheinrich service who sent him a technician to do a diagnostic and again, his Judit (Diagnostic equipment) didn't read the part either. Adding to that, he mentioned that the Reach Truck has another similar part with the same number but installed underneath the Hydraulic. He finds it too weird that both parts have the same number, which is something I never noticed before and doubt is a manufacturing error.
Does anyone have an idea of what the issue could be and how to get around it? It is a hassle when a client orders something specifically and is half the world away, while we cannot review the real issue.
I appreciate your feedback.
  • Posted 22 Oct 2018 10:43
  • Modified 22 Oct 2018 10:43 by poster
  • By AASup
  • joined 22 Oct'18 - 4 messages
  • Austria
hi mi friend, can you sharre with me the manual???
cesario931*gmail com
please, thanks in advance
  • Posted 7 Oct 2017 15:21
  • By gerardo_a
  • joined 14 Apr'09 - 54 messages
  • United States
cgonzalez@indirep.com.mx
I have the same error code 0802 EFG 316
Who can send me user manual to reslove this problem plz
  • Posted 24 Jun 2017 21:50
  • By driton_m
  • joined 14 Jul'16 - 4 messages
  • Kosova, Albania
Model ETV Q20
Tested all coils, all within 15-30ohms
Inspected wiring, found nothing unusual or exposed.
Found cracked sensor on outter LS of mast and open slot 9f2 (7.5a/58v) fuse.
Switched fuse with same rating 1f13 slot, code did not change.
  • Posted 4 Dec 2015 04:48
  • By Truetechnicians
  • joined 4 Dec'15 - 3 messages
I am having the same 0802 problem. Im a virgin with these lifts. Help please?
  • Posted 4 Dec 2015 02:57
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
SMV (Konecranes) 16-1200C
Bolzoni SpA (Group HQ)
USD1
