Mitsubishi
what generation is this lift, model#FGC-30, serial#AF83B-00508. Went to order parts to repack tilt cylinders and was asked what generation i had 1,2,or3. How can you tell which one you have.
  • Posted 22 Jul 2013 08:49
  • By GregM
  • joined 2 Apr'12 - 26 messages
its not a genration thing they are looking for
the parts manual specifies 01, 02, 03 and those being Gas, LPG or Duel Fuel (GAS/LPG), all in that order.
01= Gasoline
02= LPG
03= GAS/LPG (Duel Fuel)
The most common trucks on the market are the LPG trucks and the the packing kit part number for those trucks is 9430430140. Takes 2 kits if your doing both. There may be a sequence change in part numbers and a newer one available but just give them this number and it should suffice. Actually i checked all the packing kits for all types and they are all the same. ;o)
The only time you would run into model type problems is if you needed any hard parts like rod's or packing glands etc. But as for the packing kits they are all the same.
good luck
  • Posted 24 Jul 2013 03:54
Neutron stars, the remnants of supernova explosions, have such extreme density that a tablespoonful of their material would weigh over 1 billion tons on Earth.
August 31 - September 2, 2025 - Sultanate of Oman, Oman
September 9-11, 2025 - Birmingham, United Kingdom
Olathe, KS, United States
Dallas/Ft Worth, United States
Gillian Reed Gillian Reed
Board director, UKMHA
Director, ICHCA Australia
Senior manager of powered access business development & technical services North America, Noblelift
VP business development for Europe, Noblelift Intelligent Equipment Co
