Nissan 3 wheel electric 1N1 brakes
I have got a nissan with excessive brake pedal travel. Replaced master cylinder but its still the same there doesn't seem to be excessive travel of the cylinder approx 3mm movement on the cylinder. Is this normal and is there any adjustment of the brake cylinder etc. i can't find anything in the service manual. Brakes operate fine but pedal movement seems excessive.
  • Posted 10 Jul 2013 22:38
  • By Leon_W
  • Tyne & Wear, United Kingdom
These brakes will need to be back bled and rod set up with slight free travel. Adjusting the park brake cables so that it presses on the pin a little will buy some time. Look in service manual for pin travel tolerances and service brake discs if required. Being a wet set up they should give long service life.
  • Posted 15 Jul 2013 10:28
  • By RCAV8TOR
  • Alabama, United States
hello leon the 1n1 has always had a fair amount of travel in the brake pedal just a very bad design if the unit pulls up ok it is usually ok the brakes are like a clutch pack arrangement same as an auto trans the plunger piston is very small and does not travel very far.as for the electronics well that's another nightmare
  • Posted 11 Jul 2013 20:24
  • By electrotech
  • joined 15 Apr'13 - 63 messages
  • Victoria, Australia
Reach for the sky
  • By electrotech
Reach for the sky
Hello Leon, We had some while ago the same problem. We had to open the brakes and replace springs inside. Take a look at the 2 wheel brake cylinder and see if you release the brake pressure the pin of the wheel brake cylinder is coming out. If it is OK try to adjust the handbrake cables.
Marcb
  • Posted 10 Jul 2013 23:53
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
Gillian Reed Gillian Reed
Board director, UKMHA
Director, ICHCA Australia
Senior manager of powered access business development & technical services North America, Noblelift
VP business development for Europe, Noblelift Intelligent Equipment Co
Dallas/Ft Worth, United States
Olathe, KS, United States
Kalmar DCG16-900
Aichi RX07B
F. Uchiyama
Neutron stars, the remnants of supernova explosions, have such extreme density that a tablespoonful of their material would weigh over 1 billion tons on Earth.
