RX20-20 /A2815
Still ,RX20-20 error code A2815 is coming.
I had installed new speed sensors and Checked the input votages to the Speed sensor, it seems to be correct. But drive is slow speed. some times only one wheel is rotating. Please suggest.
  • Posted 27 Jun 2013 17:19
  • By lishoy_t
  • joined 29 Oct'12 - 70 messages
  • dubai, United Arab Emirates
lishoythomas619@gmail.com
Hello,
Look on the external power supply (if the truck has optional like lights, beacon) on the left side in the back. On the truck can be mounted maximum 3. If one of them is defective then there is not enough power (amps) to supply the options and the options will try to get power from the supply unit (SU) and that will not be good and in time you will get again the same problem.
Best regards.
  • Posted 8 Jul 2013 19:35
  • Modified 8 Jul 2013 23:42 by poster
  • By Dejavu
  • joined 27 May'10 - 40 messages
  • Bucuresti, Romania
It may look like I'm doing nothing, but in my head I'm quite busy.
Hello Friends !!
The Problem is rectified , the Supply unit was Faulty !!!
  • Posted 29 Jun 2013 18:53
  • By lishoy_t
Hello ,
I had just opened the Supply Unit and found the Smd resistor is burned. I had Installed new one.but the complaint is same. If I install new Supply Unit , will the machine works smoothly.
  • Posted 29 Jun 2013 15:35
  • By lishoy_t
Hello ,
I had put both drive converters on other machine of same series and found working normally. I had also interchanged the both traction motors and found no defect. please suggest.
  • Posted 28 Jun 2013 21:03
  • By lishoy_t
Hi friend,
Yes, this is the problem caused by the speed measuring system of the right hand motor converter : If speed sensor and wiring feed back - supply voltage are all OK. Just try to swap over the right and the left converter to see if the problem caused by the internal converter or not ?
Good luck
  • Posted 27 Jun 2013 21:27
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
August 31 - September 2, 2025 - Sultanate of Oman, Oman
September 9-11, 2025 - Birmingham, United Kingdom
Olathe, KS, United States
Dallas/Ft Worth, United States
Gillian Reed Gillian Reed
Board director, UKMHA
Director, ICHCA Australia
Senior manager of powered access business development & technical services North America, Noblelift
VP business development for Europe, Noblelift Intelligent Equipment Co
edition #1241 - 31 July 2025
CeMAT Australia was held in Sydney last week with a larger than usual contingent of Chinese OEMs. Forkliftaction speaks with a number of them to find out why they are targeting the Australian market, and what they feel needs to be done to be successful here. It’s an interesting insight into a shift in the market which is seeing some of China's largest companies making a move... Continue reading
