Hyster J2.00XMT - "Low Voltage Steer Sensor" - showing on dash
Can some one please provide information as to how we can check / test repair fault - machine slows and then speeds up intermittantly even when accelerator pedal is kept fully down but dash information always shows " low voltage speed sensor" Any assistance greatfully received.
  • Posted 20 Jun 2013 18:04
  • By Reddog
  • joined 23 Feb'09 - 58 messages
  • Wrexham, United Kingdom
Thank You John - I will try that on next visit - you don't have a service manual for one of these machine by any chance ?. Regards Kyle.
  • Posted 26 Jul 2013 23:28
  • By Reddog
Take of the rear cover and you wil find a bleu potmeter in the steering assy, drive the truck forwards and backwards untill you drive perfectly straght.
Use your DMM in Volts function and measure between the middle pin of the connector of the potmeter and the left and right pin.
The readings should be the same.
Replacing the potmeter is always ok on this kind of trucks.
I used to replace them evere 2000 hours to prvent problems.
Regards John
  • Posted 26 Jul 2013 23:11
  • By Johnkivits
  • joined 25 Jul'13 - 10 messages
  • Gelderland, Netherlands
Toyota 8FD45
Taylor TX175
New - Sale & Hire
August 31 - September 2, 2025 - Sultanate of Oman, Oman
September 9-11, 2025 - Birmingham, United Kingdom
Neutron stars, the remnants of supernova explosions, have such extreme density that a tablespoonful of their material would weigh over 1 billion tons on Earth.
edition #1241 - 31 July 2025
CeMAT Australia was held in Sydney last week with a larger than usual contingent of Chinese OEMs. Forkliftaction speaks with a number of them to find out why they are targeting the Australian market, and what they feel needs to be done to be successful here. It’s an interesting insight into a shift in the market which is seeing some of China's largest companies making a move... Continue reading
