Linde h16 cooling fan
Hi ,
I have a Linde gas truck and the cooling fan is always running. There is a permanent feed to the resistor for the fan speed, even if the cooling fan switch is disconnected.
Any advice would be appreciated
Thanks
  • Posted 30 May 2013 05:36
  • By richard_e
  • joined 17 Nov'10 - 30 messages
  • staffs, United Kingdom
Richie
Hello , thanks for that.
If you have a diagram that would be a great help.
  • Posted 30 May 2013 21:58
  • By richard_e
Richie
The fan is controlled by a small black box behind control valve, and inside this box there are 3 small relays controlling fan speeds. Also in this side there is another relay (9K4) controlling max fan speed.
Do you need wiring diagram?
Regards
  • Posted 30 May 2013 07:49
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Hi Richard,
if this is a 350 the cooling fan should run at slow speed all the time, as soon as you turn on ignition.
as truck warms up the speed increases
  • Posted 30 May 2013 06:43
  • By ian_h
  • joined 11 Sep'08 - 149 messages
  • United Kingdom
Muncie, IN, United States
Deborah Baker Deborah Baker
