Intermittent error code e 115
The jack works for a few min then throws the code. Ive checked the battery's and the main contacter and alls well. I need help bad this jacks making me look bad. If it were mine I'd tear out all the Raymond electronics and run a pot directly to the Curtis controller
  • Posted 8 May 2013 06:41
  • By jarid_b
  • joined 8 May'13 - 5 messages
hi there good to see you found the fault something I learned along time ago never assume anything especially what customers tell you as for information this site will always help you I guess.
and as for raymonds I used to have a similar opinion years back when I wasnt familiar with them but I have been a tech for 30 years and seen a lot of units over that time they are at the top of my list as one of the best
  • Posted 13 May 2013 19:13
  • By electrotech
  • joined 15 Apr'13 - 66 messages
  • Victoria, Australia
Reach for the sky
i had originally diagnosed the jack as having bad batterys and the customer chose to put them in themselves. then i was called backout cause it wasnt working, i got there and it worked fine, and i got called back the next day (keep in mind that this is the first job ive done for this company) turned out the customer only replaced two batterys ,and the other two were caked in corrosion. i hate raymonds and thanks for your help. woul any one know where you could get r a y m o nd di agn o s is software
  • Posted 13 May 2013 05:07
  • By jarid_b
code e115 - contactor off, welded or missing or bad power amp.
check for low voltage as electrotech said, get a good load on the forks when you are checking.
these trucks are notorious for strange codes when working with 1 bad 6 volt battery in the pack. also the harness can wear through in non visible areas under the steer arm stem.
  • Posted 12 May 2013 10:17
  • By stam
well ill check that when i get to work ,if it works then ill post it, thanks
  • Posted 10 May 2013 20:10
  • By jarid_b
  • By jarid_b
hi there silly question did you check the battery? check the two micro switches at the base of handle check also the stop switch check continuity across the red safety switch I still cant see that code but you possibly have a faulty Curtis controller as I think that code is a checksum software error good luck
  • Posted 9 May 2013 19:25
  • By electrotech
Reach for the sky
i turn on the 102t-f45l and when i lower the handle sometimes it works sometimes the relay clicks 3 times and "e115" comes up on the screen. sometimes the main contacter clicks on then off then e115 comes up on the screen when i lower the handle
  • Posted 9 May 2013 14:53
  • By jarid_b
hi jarid b are you sure its code 115 ? and not 151 ? there is no listing code 115 for this model
  • Posted 8 May 2013 21:46
  • By electrotech
Reach for the sky
  • By electrotech
Reach for the sky
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
