No operation
When powering up unit it is staying in self test on the display. There are no codes being displayed and will not operate. This unit is new to us. Any help will be appreciated.
  • Posted 3 May 2013 06:18
  • By Kono
  • joined 14 Oct'11 - 9 messages
  • Alberta, Canada
Did any cables get damaged?Check key switch,if good most likey firmware or bad managers
  • Posted 4 May 2013 03:06
  • By hayward_a
  • joined 3 May'13 - 5 messages
Do you have the superword?
Self test is checking all the devices and communications between the unit controllers. You will need to read the codes on the controllers as it goes through self test. It could be something so simple as a bad or out of adjustment foot pedal switch, to a blown fuse to a bad vehicle or carriage manager.
  • Posted 3 May 2013 23:13
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
Esie Cortez Esie Cortez
Oxford Ct, United States
