mast is lowered slowly
HI, i have a raymond 7400, hidraulic motor is DC,
mast is lowered slowly, check lift pistons gaskets, new oil change, new filter, clean maniful and all valves.
proportional valve adjustment, bleed system and continues to decline slowly.
Someone has something similar happened???
thanks so much!!!
thank you very much for your possible help!:
THE MAST LOWER ALONE.... without moving hand control.
IN 1 HOUR, LOW 1 INCH, NO LOW UNIFORM, ONLY IN MOMENTS.
  • Posted 15 Apr 2013 07:14
  • Modified 16 Apr 2013 03:06 by poster
  • By richardson
  • joined 15 Apr'13 - 6 messages
  • n.l., Mexico
richardson
If you're still having that problem check free lifts flow control valve and make sure it's not busted. Location is inside free lift where hose connects. Disconnect hose and take flow control valve out.
  • Posted 11 Sep 2024 00:34
  • By D_Lopez
  • joined 25 Apr'22 - 8 messages
DLopez
I am glad i took the time to post what was wrong with your truck.... why do i even come here. Nobody can ever help me.
  • Posted 1 May 2013 19:56
  • By stam
Thanks RAY TECH, your comment is the most successful...
The oil and filter are new.
In this model is 7400 DC, the manifold is larger and with more components than 7400 AC.
The 7400AC is the load holding valve, it has a red **** on top.
In the 7400DC The load holding valve is different, dont exist the red **** to lower network manually.
Apparently the problem is the valve, the internal spring is damaged, not strong enough, and oil leak into the tank
Sorry for my little English.
Thank you for your comments and support.
  • Posted 1 May 2013 03:34
  • Modified 1 May 2013 03:40 by poster
  • By richardson
  • n.l., Mexico
richardson
I agree with swoop, the 1 inch in 1 hour drift rate is going to be well within the manufacturers acceptable drift rate.
  • Posted 22 Apr 2013 00:05
It could be The load holding valve, it has a red **** on top. First of all, Did someone push on the **** and release it.....That`s all it takes. In an emergency lower of the tellies, you would depress the red ****, then screw in the prop valve adjuster until the mast lowered. If the **** is in the correct position, the load holding valve is stuck open. I would check the hydraulic filter for iron filings. TIP: to replace the filter without any oil coming out, raise the tellies up out of the free lift a few feet. There will be oil gushing out when you remove the filter. Most likely you will find iron filings in the system. they come from free lift cyl cushions falling apart. You must check for filings first, clean them out with magnet in hole, if you find any let me know, i`ll tell you what to do next. To test, Swap the load holding valve with another truck. Dont raise the tellies to replace the load holding valve!!!!!
  • Posted 21 Apr 2013 22:04
  • Modified 21 Apr 2013 22:13 by poster
  • By EasiTek
maybe relearn the Pot, if this model still has that type of system?
  • Posted 16 Apr 2013 08:59
  • By cownd
  • Arizona, United States
orchidlane29@gmail.com
most manufacturers have a drift rate and allow a certain amount of drift in a predetermined amount of time. 1 inch in 1 hour may be in excess of raymonds parameters or maybe not. I would check the service manual and see what the allowable drift is for this truck.
  • Posted 16 Apr 2013 07:38
I have experienced this before, for me it was a bad load holding valve, but i had current to the solenoid coil, do you?
  • Posted 16 Apr 2013 05:30
  • By stam
NOTE::::
  • Posted 16 Apr 2013 03:01
  • Modified 16 Apr 2013 03:07 by poster
  • By richardson
  • n.l., Mexico
Yes, i change the prop valve, and change oil, filter and clean system.
The programing set is ok.
  • Posted 16 Apr 2013 02:43
  • By richardson
  • n.l., Mexico
richardson
Is the programming set to slow lower?
Have you tried replacing the proportional valve?
Is the hydraulic tank vent (the cap) clean?
  • Posted 15 Apr 2013 23:51
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
Esie Cortez Esie Cortez
Toyota 02-8FD30
Crown WP302020
Oxford Ct, United States
