display shows "Lo"
In our forklift Caterpillar ,EP20KT the display is showing "Lo". What May be the reason? Firstly it comes error 60 and we checked the cables to the display from logic card. And we tried with new logic card , then error code turned to 65 and we had arranged DSW as per the truck details , Then the error code is vanished and the display is showing "Lo " What may be the reason ?
Note : Battery is in good condition
  • Posted 12 Apr 2013 00:19
  • By lishoy_t
  • joined 29 Oct'12 - 70 messages
  • dubai, United Arab Emirates
lishoythomas619@gmail.com
oh yeah, one more important thing.
you HAVE TO have the DSW set to 'setup mode' before the system will accept any changes and store them in memory.
This is why i suggested to doublecheck the DSW switch and wiring.
good luck
  • Posted 8 May 2013 06:53
Thanks, Guys
Your info. is very helpful.. I will try again and let you know
Regards
  • Posted 8 May 2013 06:30
  • By for_y
  • joined 21 Apr'10 - 63 messages
  • Sao Paulo, Brazil
thetarget7@ymail.com
65 is logic card, faulty initial setting
possible causes are:
faulty DIP switch (DSW) setting on logic card
model not set
or faulty logic card
i would check all your connector plugs, wiring associated with them and check the DSW switch and make sure its working, wiring on it is good, no loose or broken wires.
  • Posted 7 May 2013 12:26
Hello. Guys
I have the same error ''65'', i follow the steps refer to the shop manual. But,i cann`t complete the ''SUO'' group 1&2 because there is no response. any ideas, please.
Thanks
  • Posted 7 May 2013 08:03
  • By for_y
  • Sao Paulo, Brazil
code 60 means no serial communication (a serial communication fault)
Lo = Low battery
if you have a discharged battery it can cause the code 60
check you battery and all connections and fuses
  • Posted 13 Apr 2013 03:06
Hello friend.
See your email
Best regards, Laci
  • Posted 12 Apr 2013 16:13
  • By LACI
  • joined 24 May'09 - 195 messages
  • Serbia
SMV (Konecranes) 12-1200B
Komatsu FD25T17
Muncie, IN, United States
Deborah Baker Deborah Baker
