code 44
Got code 44 on my raymond opc30tt
Said pc contactors closed when damand opend check the
Coil resistants ok any clues to the problem
  • Posted 5 Apr 2013 12:45
  • By robbiekds
  • joined 5 Apr'13 - 7 messages
Thanks guy I will try it out let y'all know how it works
  • Posted 9 Apr 2013 12:09
  • By robbiekds
Check for shorts to frame. Check static strap and standoff...unplug battery, put ohmeter on strap and frame, should be 10 thousand ohms resistance. If none, the 10k resister is fried. Expensve to replace, just get the resister.. Use a quality contactor, no clone crap. It has to snap open real fast
  • Posted 7 Apr 2013 09:43
  • By EasiTek
did you ever see it work? perhaps the sense line for the contactor is on the wrong spot and getting b+ all the time instead of only when the contactor is closed.
  • Posted 6 Apr 2013 17:22
  • By stam
Contact tips are ok I did check the fuses to the contacts and they were 2 ohms the coil were 18 ohms and the other was 39 ohms tryed replacing coils a contacts didn't make a difference
  • Posted 6 Apr 2013 10:44
  • By robbiekds
usually it is welded contact tips. do they look ok?
  • Posted 6 Apr 2013 07:44
  • By stam
Dwight Klappich Dwight Klappich
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Executive director, NT WorkSafe
Chief executive, Logistics UK
The black box flight recorder was invented by Australian scientist David Warren in the mid-1950s. While initially met with indifference in Australia, his invention gained international recognition, particularly in the UK, and is now a mandatory piece of safety equipment on all commercial aircraft.
Hyster-Yale reports Q2 operating loss Cleveland, OH, United States
