EE Rating
i am trying to find out for sure the rules on EE rating i understand the basics but i am looking for detail
example :
aftermarket strobe lights and if OE is required what about wiring if has already been changed
shock watch wiring can you just splice in and still hold EE
in saying this is there somewhere i can find the " rules " myself i am sure there is to much for here
thank you in advance
  • Posted 1 Mar 2013 05:08
  • By LIFTERIC
  • joined 1 Mar'13 - 1 message
yes john is absolutely correct on this
getting a truck certified as any rating other than its original rating is an expensive proposition, I've done a few of these over the years and depending on what type of rating you want to make the truck in question its generally alot of work.
If you want specifics as stated by OSHA you can check this out here: hxxp://w w w.osha.gov/pls/oshaweb/owadisp.show_document?p_id=9828&p_table=STANDARDS
(you can correct the spaces and erroneous characters I've added to the URL to make the link work).
but I'm sure you may have already been here looking for your answers and these are just general requirements from OSHA that cover a complete range of equipment in a specific market area.
If your looking for details about how to perform the work?
It's fairly simple as to how to make a truck 'spark proof' or 'explosion proof' , ANY electrical connection or device attached to the lift has to be sealed in such a manner that it is air-tight.
All connectors, terminal exposed, panels exposed to the atmosphere that vapors can get to, any component that generates a possible spark has to be sealed up and made air-tight. All applicable signage/decals and literature for that rating has to accompany the lift and it has to be re-certified to the rating it has been altered to by a certified person or company.
If you check with your manufacturer you most likely can find that most of them have kits that are designed to convert lift-trucks into spark proof trucks.
But as john stated, it is a VERY expensive proposition to consider.
  • Posted 1 Mar 2013 22:09
  • Modified 1 Mar 2013 22:10 by poster
It is simple when you understand how an EE rating is applied to a lift truck. The actual EE rating lable or LPS or DS safty rating are applied by a UL representative as the unit was shipped from the factory. ANY modification to the electrical or fuel/exhaust sytem after it ships will void the EE or LPS or DS rating. If the customer insist a modification is required & must still have the unit rated EE, etc. it is an expensive proposition -someone pays all travel expenses for a UL representative to come out to the locations and a hourly charge for his time & documentation fee - need the BIG check book to pay the total bill.
  • Posted 1 Mar 2013 12:59
  • By johnr_j
"Have An Exceptional Day!"
Muncie, IN, United States
Unicarriers FD80-2
Manitou M50-4
Deborah Baker Deborah Baker
