Thanks for the info, I cleaned out the motor and set the steering back to standard. Has done the trick.
Ok try...fredt(at)gmail(dot)com
Thanks
Your mail does not work.
The error That the other server returned was:
552 5.3.4 Message size Exceeds fixed maximum message size
Thanks for your reply geroj.
And you have mail ? : - )
Err 57
Steering controller Check motor; check actual angle
ACTUAL VALUE potentiometer, rectify mechanical
TRANSMITTER wheel block,
AS4803L: Check incremental
bearings, replace component,
Check actual value transmitter wire
breakage signals
PM2402L check operating mode
Err 60
Swivelling bolster does
not follow steering wheel
directions
Deviation of > 15' for
looms
The wheel turns more
than 5 without change of
nominal value on steering
wheel, less than 2% sec
after reaching the
nominal position.
Tyres over-tensioned, the
actual value cannot follow
Check steering bolster mechanics:
check chain and chain tension; check
motor; check actual value transmitter
attachment,
Check tyres, replace wheel if
necessary
Hi, I have a ETM214 with ac motors (dc steer). It has various intermittent steering faults 57 , 60, 61. Is there any chance I could have a copy of the manual.
Does any have any ideas on this one?
Thanks
ETM/V14/16 -1995
catalog 1003296
see mail
