Caterpillar GP20CN error code E21
Hello!
Can someone help me with error code E21 on Caterpillar GP20CN,... the serial N is ET34-60029 if needed. I need to know what it means.
Thank you in advance!
  • Posted 8 Feb 2013 00:47
  • By mhonotone
  • joined 8 Feb'13 - 11 messages
  • Sofia, Bulgaria
in other words check the wires at the plug going into the harness connector at the air flow sensor, you might find one of them broken. Giving a tug on the wires will tell the story, if one pulls out then you have your open circuit. A bit of solder can repair this easily :o)
  • Posted 11 Feb 2013 21:07
Thank you! (bow)
  • Posted 11 Feb 2013 17:13
  • By mhonotone
  • Sofia, Bulgaria
E-21 Air flow meter fault
1. When air flow meter output current of 0.5V
or less (break or short) continues for a length
of time while engine is running.
2. When air flow meter output current of 4.9V
or more (break or short) continues for a
length of time with the engine stopped (key
SW in ON position)
Hope this helps you
  • Posted 8 Feb 2013 06:14
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
A good engineer is a helpful engineer
Muncie, IN, United States
