Error code
Hi. I was wondering if anyone has any ideas...
When I turn the wave on it first does the beep sound but then the screen turns off. I tried replacing the controller and also I replaced the batteries but still the same the same thing errors.... i uploaded a video on youtube of what happens:
www youtube.com/watch?v=RNHKC0F-tt8
  • Posted 15 Dec 2012 05:34
  • Modified 15 Dec 2012 06:07 by poster
  • By Giovann
  • joined 20 Sep'11 - 8 messages
" can" , also faults 43 & 44 are displayed when the communication lines have an issue. Could be shorted or open can wires, can wiring shorted to batt positive, or a bad display or controller. You'll need to test the can wires ( starting @ the controller - CA401 pins 3 & 4, follow thru CA501 pins 3 & 4, thru TB301 pins 3 & 4 which is the control cable connection, up to CA101 pins 5 & 6, to the display - CA701 pins 5 & 6. If the wiring tests ok, your looking at either the display or the controller.
  • Posted 25 Apr 2013 21:45
  • By roadtek
  • joined 4 Dec'07 - 123 messages
Curtis has a lot of stuff on their website, have you tried there? curtisinstruments (I think)
you might add your e-mail to your profile, it won't show here, for good reasons.
  • Posted 25 Apr 2013 09:40
found CAN Fault hooked up Curtis hand set. don't know what it means, dont have manual
  • Posted 25 Apr 2013 05:11
  • By All Lift Tech
  • joined 3 Oct'10 - 57 messages
I swapped then out from and still the same problem
  • Posted 24 Apr 2013 22:18
  • By All Lift Tech
batteries are (naturally) the first thing to check.
are they all good and well charged and stand up to load testing?
  • Posted 24 Apr 2013 19:59
I have the same issue with my wav50 did you have any luck with yours
  • Posted 24 Apr 2013 05:13
  • By All Lift Tech
I agree with crownie, aside from any of the panel switches or platform ED switch/connections, check the plugs in the back of the service panel. They habitually come apart. Just use a wire tie to secure is so. Also the fuse holder in the service panel is a common problem.
  • Posted 26 Jan 2013 00:53
  • By roadtek
check all your service panel switches and ED switches are in correct positions
acts like drive/push switch is open circuit, could be plug connector to service panel
  • Posted 15 Dec 2012 08:34
  • By crownie
  • Victoria, Australia
Ice 28INCH-AUTO-SCRUBBER
USD8,350
TCM FHD105Z
Libiao Robotics
