Linde E15 386 2007 errors L294 L295
what this error means ?
thanks
  • Posted 7 Dec 2012 18:43
  • By max_f
  • joined 7 Dec'12 - 2 messages
  • swietokrzyszkie, Poland
Hi,
The problem is probably on both joysticks.
Check the calibration, but probably you have to replace them.
After the replacement the joysticks should be calibrated, but if you do it reasonably (with all positions on null, more or less) the problem may be solved without calibration.
  • Posted 10 Dec 2012 22:34
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
hi
thanks for your answer.
Do I have to replace the joystick? Is adaptation required after replace ?
  • Posted 9 Dec 2012 20:04
  • By max_f
L294; Current measured at joystick for tilt function raised
L295; Current measured at joystick for additional hydraulics 1 raised
Regards
  • Posted 8 Dec 2012 09:26
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Muncie, IN, United States
