Transmission
Hi
Does anyone have any info on pressure readings for the transmsission on a Yale GDP30TF?
We have reverse but no forward, all wiring checks out and solonoid all ok.
Thanks in advance.
  • Posted 26 Apr 2007 20:41
  • By danny_k
glp040 sounds like the converter is shot.If it wont climb an incline or boggs down real bad accellerating in fwd or rvs.
I have found this many times with descent converter pressure readings. Torque converter pressure is the only reading in a tranny that I don't trust what the reading says. Remanned converters are to inexpensive today to mess around with it.
I have seen to many people including myself chase their tails on a converter reading being ok and the converter is not.
  • Posted 27 Aug 2008 05:17
  • By bigGlittlestar
  • joined 12 Aug'08 - 139 messages
  • United States
whats after glp040... af totally different transmission. rf/tf are the same. if its af clutch packs burn out. smell your trans oil for burning or just could be too low.
  • Posted 3 May 2008 05:08
  • By kevin_k
GLP040
Would these readings apply? I have this problem.good firm reaction, F&R but no power to walk over a piece of 2 by 4 wood at stand still. Seems to be a pressure issue.
Thanks
  • Posted 30 Apr 2008 00:04
  • By BluzGtr
  • joined 12 Jun'04 - 5 messages
check the position of the reverse switch under the direction control lever
  • Posted 28 Apr 2007 20:51
  • By danmar
  • joined 28 Apr'07 - 2 messages
  • Romania, Romania
danny
port1 140>170 psi (pump pressure. next to dipstick
port 2 105>125 psi (forwrd clutch. front of control valve next to dump spool)
port 3 105>125 psi ( rev clutch. down below throttle pedal off the control valve.rear of two ports.
port 4 105>125 psi (torque conv pressure. just across from port 1. behind filter
port 5 15>25 psi ( lube pressure. next to port 3 under throttle pedal
port 6 variable ( modulater pressure. below rear solenoid. varys on position of dump/inching spool
hope this helps mate but still reckon that circlip has come out. quite common problem. mast off job. easiest way is to drag transmission out the front leaving engine sitting. with practice you can have transmission on the floor in 2 hours. no need to strip brake hubs off or pull half shafts.if you get stuck just shou back
  • Posted 27 Apr 2007 05:31
  • By kevin_k
hello danny. i can tell you from previous experience on this transmission that you probably have a blown out clutch pack. large circlips tend to fly out. i can get you the setting as they same as hyster. does the oil stink of burning ??
  • Posted 27 Apr 2007 05:11
  • By kevin_k
Maxlion R2D35
SMV (Konecranes) 33-1200C
