Jungheinrich Reach truck with mokropulse steering help needed
i have got a reach truck that was showing fault 5 or S. Which indicates steer head faulty. i have replaced the steer head but now i have a line at the top and a line at the bottom. Has anyone got a copy of the setup procedure to send me please. i have some info with fault codes but nothing for setup. Looks like its trying to select right and left trun together.
  • Posted 6 Aug 2012 22:39
  • By Leon_W
  • Tyne & Wear, United Kingdom
I have repair a old jungheinrich reach truck.
I have no fault code explain. it's too hard adn headache.
Could anyone send a fault code list to me.
BEST regards
  • Posted 17 Aug 2012 15:14
  • By shar_k
  • joined 30 Jun'12 - 37 messages
  • SH, China
E-mail:kunshar@qq.com;xiakun223@163.com
sorry so long have you got set up now if not email me
  • Posted 16 Aug 2012 06:22
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
Hi.
Check your mail....
  • Posted 15 Aug 2012 00:57
  • By Fittermax
  • joined 17 Jul'08 - 171 messages
  • Denmark
Hi.
the 2 pots are 1: for adjust half voltage at center (after mechanical adjustmenthas been done) 2: for gain, but this can also be done on controller. Airgap is to be so big that the sleeve/bushing can operate up/down and NOT touch attachment ring. Be sure everything "runs" freely. I'll see if I can find old workshopmanual. This forklift was taking out in 1994-1995.
Regards, Max
  • Posted 15 Aug 2012 00:32
  • By Fittermax
  • Denmark
Hi Max, have you got a copy of the setup instructions. There is 2 pots, which one needs to be adjusted? How much of an airgap is needed?
  • Posted 14 Aug 2012 23:35
  • By Leon_W
A line at top and bottom, is sensor out of adjustment. It's a litle tricky to adjust this sensor board. If I'm correct you have 4 wires. Supply (+ and-) for sensor. Sensor output and finally checkwire for broken wires. Plus and minus is 5 V and sensor output has to be exactly half supply. You can adjust the sensor PCB up and down, but be sure there is an airgap by attachment ring at top.
Any further questions, just ask. Regards, Max
  • Posted 14 Aug 2012 20:07
  • By Fittermax
  • Denmark
Hi Trevb,
did you manage to find any info on setting up the steering sensor?
  • Posted 14 Aug 2012 17:39
  • By Leon_W
will try to get some info i think the two bars are saying its ok there is a distance set up on the sensor but that gives you stronger feeling, mind it doesnt take your hand off if you play with that , think there are a couple of pots you can tweek as well will try to get info not back in depot till mon though
  • Posted 7 Aug 2012 23:09
  • By trevb
Its fairly old has got a sensor on the steering coloum with a round magnet in the middle as you move left or right an actuator lifts up or drops down slightly to tell the motor what direction to rotate. There is an amplifier under the plastic arm rest next to the rest of the electrical components and that has the segment display with error codes etc.
  • Posted 7 Aug 2012 17:05
  • By Leon_W
is this the 95 type reach truck with large steer card by steering wheel , fly wire steering or the old etm with silver mp think its a 516, it has a removable top card with segment display might be able to find some stuff for you
  • Posted 7 Aug 2012 07:53
  • By trevb
SMV (Konecranes) 4632CC5
SMV (Konecranes) 33-1200C
