Linde H30D, 393 series truck surges when hot.
Once hydraulic fluid is hot the truck surges in forward and reverse at low speed only. All pressures check out good. Blew compressed air into port Y and Z (forward and reverse) of hydrostatic pump and air was bypassing through the servo pistons seals. We replaced seals and the truck worked fine...but only for 90 hours.
Found once again that piston seals were bypassing. Disassembled pump, seals and pistons where seals ride are like new. Reassembled the pump and now piston seals hold pressure but I don't think that the issue is permanently solved though.
Any ideas??
  • Posted 17 Jul 2012 21:35
  • By duodeluxe
  • United States
duodeluxe
if you're talking about the travel surging,
3 solenoids in a row on trans under air filter box,
take the outer ones(not middle) off and see if they are
shiny(not corroded), sometimes you can buff up the cores a bit,
or change core and solenoid,
that's for surging/ choppy travel at low speeds.
  • Posted 19 Jul 2012 09:48
  • By ddrr
  • joined 27 Jul'06 - 16 messages
  • Alberta, Canada
this is common you have to replace the valve block on the pump they develop hair line cracks internally if the truck has had a hard life this is the cause,unfortunatley they are very expensive,hope this helps
  • Posted 18 Jul 2012 17:12
  • By fred9691
  • joined 25 Jan'12 - 11 messages
  • somerset, United Kingdom
gina@jina.orangehome.co.uk
edition #1239 - 17 July 2025
As part of Forkliftaction’s 25th anniversary celebrations, we have dug into the archive and, over the next year, will be highlighting a carefully curated selection of historical stories we have published over this time... Continue reading
Mike Barker Mike Barker
President and CEO Swisslog Americas, Swisslog
Vice president, Newgentech Material Handling India
Sales representative, Alabama and Panama City, Thompson Lift Truck
Chief marketing officer, Bobcat Company
