Hyster R30XM2- Cannot get BDi% to change??
i have replaced the BDI and had the 1310 controller rebuilt, but when i change the settings the BDI % doesn't change or reset to 100%, here is some info:
BDI reset at 2.04
discharge % at 160
Cal. at 213
truck voltage at 24.74
BDi reads 48%
  • Posted 13 Jul 2012 01:41
  • By Tracker
  • joined 8 May'12 - 9 messages
  • South Dakota, United States
how to reset the BDI:
to reset a BDI you must apply a voltage above 28voltes
how to do this:
you put more than one cell to another battery in series
with the battery from your machine
you will have about 28 volts
call for 3 seconds
and then restart the machine
eStara reset the BDI
  • Posted 16 Jul 2012 01:52
  • By hysterbrazil
  • joined 10 Oct'11 - 101 messages
  • rio de janeiro, Brazil
for placing the serial number
I check the service manual
but I think you should reset the BDI
  • Posted 16 Jul 2012 01:47
  • By hysterbrazil
and what level of handset are you trying with?
  • Posted 16 Jul 2012 00:10
The 1310 is an interface made by Curtis. It's used in Yale orderpickers (C801 IIRC). Is that your serial number code?
  • Posted 15 Jul 2012 00:48
  • By justinm
The 1310 controller what make is this ?
I have had on some zapi controllers where instead of settings the battery truck voltage to what it actually reads on the multi meter, you have to increase or decrease that voltage for the bdi to actually alter.
For example if the battery voltage on your meter reads 24.74 and you have set the controller to this voltage try increasing this and see if this makes a difference if not try decreasing.
  • Posted 14 Jul 2012 03:47
  • By elektrodrive
  • joined 2 May'08 - 740 messages
enquiries@elektrodrive.co.uk
Enforcer FLBAXT25
Toyota 02-8FD25
October 8-9, 2025 - Twickenham, United Kingdom
edition #1239 - 17 July 2025
As part of Forkliftaction’s 25th anniversary celebrations, we have dug into the archive and, over the next year, will be highlighting a carefully curated selection of historical stories we have published over this time... Continue reading
