Loss of drive R70
PLEASE HELP. Forklift stopped in middle of workshop,no drive,Cant move until fixed,the big relay clicks in when you start up,checked speed sensor that seems fine,checked hand brake lever switch that seems fine,any information would be great,Thanks.
  • Posted 7 Jul 2012 18:46
  • By landy
  • joined 5 Jul'12 - 5 messages
  • cornwall, United Kingdom
Hi we have checked the alternator,it was a new one not that long ago,there is live from the ignition light down to the d+ terminal on alternator which is negative,when you start engine the d+ terminal changes to positive putting out the charging light on the dash.the big solinoid beside the control boards clicks in,clicks out when you pull on the handbrake, alternator is charging around 27-28 volts.we have got signal from the W terminal on ALT,my friend checked this with his meter and it is sending out a frequency to the logic board,but now we are stuck,thanks for your help speak soon.Rick
  • Posted 9 Jul 2012 06:28
  • By landy
straight up across
First, check alternator signal. The controller needs this signal to enable traction.
I have no pdf manual for this truck but will try to search a wiring diagram in my pc
Regards
  • Posted 8 Jul 2012 01:09
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Hello there my friend,thanks for the reply,the serial number is 70310647 year of man;1988 v/w diesel engine,speak soon, cheers Rick
  • Posted 8 Jul 2012 00:26
  • By landy
Hi Landy,
Need the truck serial number to give you any help
Regards
  • Posted 7 Jul 2012 19:04
  • By nacsand_n
  • Madrid, Spain
Advance CS7000
Illinois, United States
USD8,000
Unicarriers FHGE35T5S
SNORKEL A46JE
Toyota 8FD35U
Flesherton, Ontario, Canada
