Llift not working
All,
Pretty stumped on this current issue. The walkie pallet jack moves forward and back fine. Hydraulics seems to malfunction periodically. Sometimes it will lift and other times it won't. No error codes are displayed and I have already replaced with a new lift solenoid. I've checked the hydraulic fluid levels and it seems to be fine. I've also swapped the handle with another one from a working pallet jack and continue to have the issue. Could it be a problem with the hydraulic pump? Are there any additional areas i need to check for wire shorts? Any help is greatly appreciated.
Robert
  • Posted 14 Jun 2012 13:09
  • By Blobby
  • joined 14 Jun'12 - 2 messages
No wiring in handle for switches. Etac card in handle uses canbus to talk to mc. Check ur lift limit sw. And wiring. Lower right side near skid plate.
  • Posted 12 Aug 2012 02:44
  • By stam
sounds like you have an open wire in the control handle harness
check the lift circuit in that part of the harness, you will probably find a broken wire near the base where it pivots
just a guess, hope its a good one ;o)
good luck
  • Posted 14 Jun 2012 20:39
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Lift Tek Elecar
