Pump motor keeps running
pump motor will not shut off, raise and lower switch are good. Only one pump motor on this unit.
  • Posted 4 Apr 2007 00:20
  • By albert_h
  • joined 22 Aug'06 - 59 messages
Can you also send me a copy of the schematics as I am having an issue with the lift as well. I can not get the lift pump contactor to engage unless i manually push it shut. I am getting battery voltage at the contactor when activating the switch. Any ideas?
  • Posted 11 Oct 2022 07:15
  • By Ricky_Gilmore
  • joined 12 Feb'22 - 12 messages
rgilmore
check your lift switches. the steer pump supplies the reach and tilt
  • Posted 16 Feb 2008 15:05
  • By whoknows
  • joined 8 Feb'08 - 10 messages
Did someone remove your e-mail address?
  • Posted 9 Apr 2007 02:43
  • By Truck_Tech
  • United States
yes its [email address removed]
  • Posted 6 Apr 2007 23:14
  • By albert_h
No,the lift pump contactor is controlled by the Multi-Function Swiitches(MFS) 1 & 2.Theses switches signal the Sequence Control Unit to turn on the pump,when that function is activated. At the top of the contactor panel,there is a box with a plastic over. That is the SCU. Inside that,there are (4) four cards,the power supply board,the seguence logic control board,the coil driver board,and the light control board. More than likely,the driver which controls the lift pump contactor is shorted. That's why the contactor activates,as sooon as the keyswitch is closed. Do you have an email address,where I can send you a schematic?
  • Posted 6 Apr 2007 07:45
  • Modified 6 Apr 2007 09:51 by poster
  • By Truck_Tech
  • United States
contactor tips are in need of change but not welded together and yes it does activate as soon as key switch is turned on? could the selector switch cause the pump to stay on?
  • Posted 5 Apr 2007 23:19
  • By albert_h
Are the pump contactor tips welded together? Does the pump contactor activate,as soon as the keyswitch is turned on?
  • Posted 5 Apr 2007 09:03
  • By Truck_Tech
  • United States
35RRTT SERIAL #W61468
  • Posted 4 Apr 2007 23:07
  • By albert_h
What model# truck is it?
  • Posted 4 Apr 2007 11:44
  • By Truck_Tech
  • United States
Enforcer FD50T-MMA
Taylor TX330S
USD159,500
