STILL FMX ERROR 0100
I have the problem reach truck FM-x error fe 0100
if anyone knows.
thank you all for the information
  • Posted 6 May 2012 02:07
  • By jefri_n
  • joined 6 May'12 - 1 message
  • indonesia, Indonesia
anybody know what means error FE0403
I didn't find it in manuals.
  • Posted 17 Apr 2014 21:23
  • By nikita_k
  • joined 13 Nov'13 - 24 messages
  • spb, Russian Federation
crash2804@ya.ru
Hi,
FE100
Description: - "FPS OK" signal (0V) is not switched by the traction and pump controller (FPS)
within 7s after "truck ON"; fault class 2.
Reaction: - All functions are disabled except steering.
Cause: - Open circuit between X1.8 (FPS) and X1.30 (FZS).
- The FPS detected a fault during run-up after "truck ON".
- The FPS detected a fault during operation.
- Faulty FPS or FZS.
Remedy: - Check the wiring.
- Observe additional fault numbers of the FPS and apply remedy depending on the
fault number.
- Check whether FPS 0V signal switches at X1.8. If it does, replace the FZS. If it does
not, replace the FPS.
Good luck
Nuna
  • Posted 6 May 2012 19:36
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
