APC 200
Can anyone help me..I am needing information on APC 200. A listing of the error codes would be super. Showing S.d.n.o and have "E" flashing. Truck kicks ino neutral when ever the mood stricks it. Turn off then it will run till next fault. This on a SMV 37-1200B.
Thanks
  • Posted 13 Mar 2012 02:20
  • By littlespark
  • joined 30 Jun'09 - 16 messages
20.60 S Pressure feed-back line is indicating there is no
system pressure present, allthough pressure should
be there
Controller reverts to a "shut down" mode and will force neutral
0
Stop machine & Contact maintenance for troubleshooting The analog input ANI0 is in the 1500 - 4000 ohm
range, while it should be in the 500 - 1500 ohm
range
Check the wiring between the controller and the pressure feedback sensor. Check
the pressure feedback sensor (engine running / stopped).
  • Posted 12 Jan 2023 06:30
  • By giorgos_k
  • joined 10 May'17 - 41 messages
  • Makedonia, Greece
Hi, i have codes t2060 and t_sht. I need a list of fault codes.
  • Posted 26 Sep 2018 21:52
  • By luke_m
  • joined 2 Feb'13 - 97 messages
  • Bedfordshire, United Kingdom
Shut-Down Mode is activated if serious internal or external fault is detected.
When the mode is activated, the transmission will be automatically
set to neutral as the redundant shut-down circuit cuts hydraulic
pressure to the connection. This mode is only selected if nontolerable faults occur.
U have to check what's error it is. Press M when there is error and check the Err, should be four numbers.
Turning off machine erase errors.
It might be pressure feedback sensore or one of the RPM sensors
  • Posted 31 Mar 2012 06:38
  • By Emed
  • joined 31 Mar'12 - 1 message
  • h, Norway
