How are they holding up?
We just completed a Hyster H80FT Fortis demo. I understand this model has been available for a couple years now. We are interested in the diesel engine unit with LED tail lights; Keyless start; Mini levers; impact monitor, and operator pre-shift checklist. They offer two diesel engines; 4.5L Cummins or Yanmar. Any opinoins would be appreciated; thanks Dave.
  • Posted 2 Mar 2007 01:24
  • By cownd
  • Arizona, United States
orchidlane29@gmail.com
CUMMINS FOR SURE, BUT STAY AWAY FROM ALL THE "WHISTLES & BELLS" HYDRAULIC FINGERTIP CONTROLLERS- APPARENTLY THEY NEED CONSTANT CALIBRATION WHICH YOU CAN'T DO UNLESS YOU CAN GET INTO THE ON BOARD DIAGNOSTICS. ALSO THE DRIVERS SAY THAT THERE IS NO "FEEL" TO THE CONTROLS. DURAMACH TRANS- DO YOU REALLY WANT A COMPUTER CONTROLLING THIS OR BRAKES ? ALSO IF THERE IS A FAULT THE TRUCK APPARENTLY SHUTS DOWN ON THE SPOT. I'VE TALKED TO ACTUAL HYSTER SERVICE MECHS, & THEY SAY KEEP IT SIMPLE. ALL THIS STUFF IS NICE WHEN IT WORKS. IT'S A FORK TRUCK , NOT A SUV.
  • Posted 1 Apr 2009 21:56
  • By OILCAN
  • joined 28 Feb'09 - 10 messages
the main problem is the plus2 transmission with power up hydraulics. you need to drive them in a certain way to keep control. not easy
  • Posted 12 Sep 2007 03:17
  • By kevin_k
It has been about 6 months without any other comments on this discussion. It seems as though these trucks are not holding up very well. NACCO is experiencing major problems with this series of trucks.
  • Posted 7 Sep 2007 22:00
  • By EasyM
  • joined 14 May'05 - 101 messages
Thanks Kevin; your feedback has been very useful to us; Dave.
  • Posted 10 Mar 2007 05:13
  • By cownd
most of the trucks we have sold minilever hyd controls which are very reliable. maybe only 1 or 2 failures out of 150 trucks. keyless start and prestart check list are all through the dash display which is fine. some cab-less trucks have had water ingress problems in the dash. haven,t heard of any problems with impact alarms
  • Posted 10 Mar 2007 04:59
  • By kevin_k
Thanks Kevin; We are interested in the thumb switch hyd. controls, impact alarm, keypad entry and, preop check list. Are these opitions dependable? Dave.
  • Posted 9 Mar 2007 08:01
  • By cownd
controls are good. we had a few faults on the hydraulics but it was just down to bad routeing of the seat wiring. if you get the correct spec for the job you are doing you should be very happy with the truck. i know the yale is basiclly the same truck but the hyster is a better specification for your money. one thing steer clear of the joystick controls somedays they refuse to work and the next they are fine.
  • Posted 9 Mar 2007 06:35
  • By kevin_k
Thanks for the responce; how are the controls holding up?
  • Posted 9 Mar 2007 02:12
  • By cownd
go with the cummins mate. yanmars are under powered
  • Posted 9 Mar 2007 01:57
  • By kevin_k
Terberg YT223
Tusk 500PGH16
Terberg YT223
Tusk 500PGH16
