Crown Order Picker Model # SP3020-30 Won't Travel in Reverse
I have a Crown Order Picker SP3020-30 that sometimes won't travel in reverse. I have blown out the Forward & Reverse Contactors and around it also. I've replaced these within the last 6 - 9 months because they were pitted. Does anyone have an idea what might be causing this reverse problem?
  • Posted 1 Mar 2012 04:49
  • By kyle_d
  • joined 1 Mar'12 - 1 message
  • Kansas, United States
Kyle Downs
Redneck Trailer Supplies
10606 E. 26th Street North
Wichita, Ks 67226
Have you checked your voltage signals on the over the mast cables? This guy has them, correct? Normally when the chains start to stretch or need to be tightened, they wipe out the conductor wire and stretch them. Same thing happens on rech trucks with carriage mounted sol valves and Raymond OP's as well.
  • Posted 22 Mar 2012 04:56
  • By chublil
  • joined 28 Jul'09 - 187 messages
Fix it right!!!
Did you check the integrity of the reverse switch? If the contactor closes in reverse it is most definetly the contactor, not usually the tip but the armature guides worn.( due to being mounted the way they are)
  • Posted 7 Mar 2012 13:24
  • By cheek
  • joined 6 Nov'09 - 25 messages
  • Alberta, Canada
I don't replace the tips, I replace the contactor. These truck are notorious for contactor problems. Put it up on a block to get the drive tire off the floor, have someone drive the truck slowly in the direction that is failing, and reach in and jiggle the contactor tips. I think you will find your problem.
  • Posted 3 Mar 2012 23:27
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
if all you did was replace the tips themselves you may want to go back and double check the insulators for wear. they do wear on one side after a while this can prohibit the movement of the armature and will not allow full travel of it. ultimately causing the tips to not make good contact or not contact at all.
if you can access the tips have someone get on the truck, (make sure the drive wheel is off the floor)
actuate the system without letting it move(in creep speed), wiggle the tips and see if the truck tries to move.
this will verify this problem.
if the contact area is enclosed and non-accessible then you just have to wing it i guess and take them apart.
  • Posted 1 Mar 2012 09:51
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
I would say its the contact tips again if contactor is pulling in and you don't have travel in one direction only. Is it coding a 24 too? I have seen this with some of the crown SP's in the past. Some times you can clean the tips up abit and it will work fine for awhile, but if pitted bad you have to replace tips. Also check the guide pin on those GE contactors sometimes they break and don't allow tips to make good contact.
  • Posted 1 Mar 2012 05:32
  • By radon
  • joined 28 Sep'11 - 62 messages
Toyota 02-8FD30
Enforcer FLBAXT25
Muncie, IN, United States
Toyota 02-8FD30
Enforcer FLBAXT25
