Error code 4A
Unit is equippped with the Vechile Manager and flashing Error code 4A. Any help would be great.
  • Posted 24 Feb 2012 04:23
  • By robin_f
  • joined 24 Feb'12 - 1 message
  • Alberta, Canada
Code 4A NOTE: If Brake Release Switch (S12) is in service mode, Code 4A will
occur during Power Up SelfTest (POST).
Corrective Actions and
Checks
1. The "X" contactor or its wiring may be bad. Run test:
* O01 - Toggle the "X" Contactor
2. The auxiliary sense circuit may be bad. Run test:
* A09 - X Sense Voltage
3. Check the 15 amp slo/blow fuse in the B+ line filter. If it is open,
check the battery. If the battery has low voltage, consider raising the
cutout percentage in the Configure Mode to prevent the fuse from
blowing again due to a low battery condition.
  • Posted 30 Aug 2012 13:59
  • By derrick_r
  • joined 28 Aug'12 - 16 messages
  • Utah, United States
Most likely blown fuse in line filter next to contactors. Usually caused by low battery voltage.
  • Posted 25 Aug 2012 11:53
  • By barry_r
  • joined 3 Aug'12 - 1 message
Nagano NUZ090D
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Esie Cortez Esie Cortez
