Codes 53 & 54
The start of the problem is when we steam cleaned unit & ran it shortly after.
After blowing out & letting dry for 7 days this is what happens.
With key off, truck will cycle dash as if key is on with in 5-10 seconds of plugging batt in. Then codes come up & unit will not operate. If key is cycled 3-4 times truck will sometimes run. If u unplug battery, & plug batt back in & turn key on before it automatically starts up with in 5-10 seconds, truck will always run & operate normally with out coding. If u then turn key off unit will power up dash with in 5-10 seconds & you are back to codes 53 & 54.
We thought it was the master Vehicle controller. Sent it out to Uniparts & they said it tested good. I have checked & blown out ever thing including dash. No water made its way to drive & pump controllers. Is this a drive controller Canbus issue?
  • Posted 22 Feb 2012 03:09
  • By Horse
  • joined 11 Jan'11 - 38 messages
  • Wisconsin, United States
"Hello, what was the solution? I have the same issue and still haven't figured out what to do."
  • Posted 23 Dec 2023 02:18
  • By Geoanzu
  • joined 21 Sep'23 - 2 messages
  • Colombia
G&M herramientas logística s.a.s
Put in new sup. mod & unit works fine.
  • Posted 24 Feb 2012 00:01
  • By Horse
Its a Danahar ac controller. I just installed the Master v controller & it still does the same.
I pulled the suppression module & I can smell a burnt smell. Just got off phone w uniparts & ordered a used 1 for $30. This makes sense to me y it fires up. Any thoughts would be appreciated.
  • Posted 22 Feb 2012 09:07
  • By Horse
Jeff Bykowski
serial number? type of controller?
I have seen water in plug to GE sepex controller do this.
  • Posted 22 Feb 2012 08:40
REPOWERTEK Inc
