Linde E-14 no hydraulic functions
Hallo,
I have a problem with a Linde E-14-02, SN H2X335L03604, year 2000. I have normal drive but no hydraulic function works. No error code appears. If I try 3-4 times to switch key on and off and simultaneously hold/move the left joystick (lift,tilt) than the hydr.functions works fine, until I switch the truck off.
Any idea???
Maybe the joystick?
I will be sure before order any false part.
  • Posted 24 Jan 2012 02:05
  • By koett
  • joined 16 Oct'10 - 7 messages
  • thessalia, Greece
koettdaagreek@gmail.com
Did you maybe know the type of hydraulic oil for this truck? It needs change.
  • Posted 25 Jan 2012 18:29
  • By koett
  • thessalia, Greece
normal is plug and play
linde trucks dond hef eror code on keyswichts
  • Posted 24 Jan 2012 07:15
  • Modified 24 Jan 2012 07:18 by poster
  • By michel_v
  • noord holland, Netherlands
Michel,
Did you maybe know if the new joystick needs calibration or something like that?Or is it plug & play ???
  • Posted 24 Jan 2012 07:11
  • By koett
  • thessalia, Greece
OK.
Thanks Michel
  • Posted 24 Jan 2012 06:26
  • By koett
  • thessalia, Greece
order one new joystik and truck is working well
  • Posted 24 Jan 2012 03:17
  • By michel_v
