Weird intermittent start up
Hi! I have started experiencing the problem with the unit - it starts up irregularly. When I turn the key on, the display lits up fine. But it might take quite a few attempts of stepping on and off the foot plate before the unit starts up. Sometimes it starts up from the first go. I thought that it might be a loose contact at the foot plate micro switch or maybe the switch itself is playing up. I have replaced both foot and motor brake micro switches but the problem is still there.
Any help you could provide would be great, Thank you.
  • Posted 26 Nov 2011 09:57
  • By GarikK
  • joined 26 Nov'11 - 6 messages
  • Victoria, Australia
All fixed! The problem was with the K1 relay.
Thank you for your help, Cheek!
  • Posted 5 Dec 2011 16:10
  • By GarikK
Thank you. I'll try that.
  • Posted 2 Dec 2011 16:23
  • By GarikK
Definetly. A poor battery creates issues. So stepping on the inner pedal does not start up the steer motor? I would check to see if you have power and ground at the solonoid. If so, change it. If not, trace what feed you are missing.
  • Posted 2 Dec 2011 12:47
  • By cheek
  • joined 6 Nov'09 - 25 messages
  • Alberta, Canada
Can the battery cause that sort of a behaviuor?
  • Posted 29 Nov 2011 17:03
  • By GarikK
Replaced all three - nothing changed.
  • Posted 28 Nov 2011 12:29
  • By GarikK
Anytime I come across these kind of issues i always start with replacing all three switches. BRK 1, BRK2, and STS1. A slight voltage drop across these switches can cause many problems.
  • Posted 28 Nov 2011 11:07
  • By cheek
  • Alberta, Canada
Thank you for the prompt reply. What actually happening is that the display lights up with the turn of the key and when I step on the floor plate (not the driving one, but the main floor plate) the relay clicks and display shows the mode of the fork (I can change the mode on the display) but nothing else is going on: pump does not kick in, neither strobe light or horn is working. When at last it starts up (after an unknown number of step ons and offs) it works as a charm: fork works fine, strobe and horn are ok, I step on the drive foot plate and it drives no problems. So I don't think the brakes need bleeding in this case as the motor switch engages every time I press on the foot/drive plate but it does not lead to anything until the unit starts up.
  • Posted 26 Nov 2011 22:45
  • By GarikK
Is the slave cylinder contacting the motor switch each and every time? Perhaps you need to bleed the brakes.
  • Posted 26 Nov 2011 13:36
  • By cheek
  • Alberta, Canada
Taylor T520M
Tusk 350CGH20
Hawker Powersource, Inc.
Taylor T520M
Tusk 350CGH20
