Display showing 'dd'
First truck had no power at all, replaced 15amp fuse and removed smashed light which had blown the fuse (I suspect!) now truck powers up briefly but then displays 'dd' and fails safe.
Im asuming that this is the logic card going into diagnostic mode?
Anyone able to shed some light on this?
Thanks
  • Posted 26 Oct 2011 16:20
  • By little_forker
  • joined 31 Jul'11 - 82 messages
insure the power fuse is good, and set the "drs" switch back to the center position. Be sure to pull the switch's "bat" lever out slightly before moving the switch, if the switch moves too easily, the locking tabs have already been damaged and you may have to replace the card (if this is one where the switch is mounted to the logics card) or the switch.
  • Posted 26 Oct 2011 20:18
