NO START
CUSTOMER RAN TRUCK DAY BEFORE, NO PROBLEMS, WENT TO START TRUCK IN AM, CRANKS BUT WILL NOT START, NO CODES,GOOD FUEL, RELAYS ALL WORK, GOOD FUSES. COULD PROBLEM BE RELAY PACK???
  • Posted 25 Oct 2011 03:21
  • By gtos66
  • joined 12 Mar'10 - 1 message
  • New Hampshire, United States
Also, sticking fuel lock valves are not unheard of. Check for fuel to the injector manifold. Check for voltage to the fuel lock while cranking the engine. If the voltage is low or missing you could have a bad relay box, I've actually seen more bad relay boxes than bad fuel lock valves, but I wouldn't call either of those problems common.
  • Posted 25 Oct 2011 09:16
  • By fixitandy
  • joined 23 Mar'09 - 81 messages
The fuel injector is sticking closed due to fuel residue in the injector itself. While cranking the engine whack the injector housing above the main injector with a wrench or the handle of a big screwdriver (don't use a hammer and don't strike the injector). It should start right up, if it does let the engine run long enough to fully warm up, if it doesn't start right up replace the injector. If it does start but the problem comes back anytime soon, replace the injector. Don't bother trying to clean out the injector housing, you'll do more harm than good. Also once you get it started up and run up to normal operating temperature shut it off and imediatly drain the sludge trap in the bottom of the vaporizer, be prepared for a stinky mess of LP fuel sludge.
  • Posted 25 Oct 2011 08:56
  • By fixitandy
Ice 24INCH-AUTO-SCRUBBER
USD6,396
UN Forklift FGL25T
USD6,396
UN Forklift FGL25T
